As far as my understanding goes, the model used for feature extraction in DeepSort is specified as the first argument of the function create_box_encoder in the file tools/generate_detections.py:
def create_box_encoder(model_filename, input_name="images",
                       output_name="features", batch_size=32):
    image_encoder = ImageEncoder(model_filename, input_name, output_name)
    image_shape = image_encoder.image_shape
def encoder(image, boxes):
    image_patches = []
    for box in boxes:
        patch = extract_image_patch(image, box, image_shape[:2])
        if patch is None:
            print("WARNING: Failed to extract image patch: %s." % str(box))
            patch = np.random.uniform(
                0., 255., image_shape).astype(np.uint8)
        image_patches.append(patch)
    image_patches = np.asarray(image_patches)
    return image_encoder(image_patches, batch_size)
return encoder
In the same file, the default value of the argument model_filename is specified under the parse_args() function to be resources/networks/mars-small128.pb, which appears to be a model for person re-identification.
Can a model for re-identifying objects other than people (and from multiple classes, such as cars, birds, trucks, etc) be used instead in DeepSort? If so, does DeepSort provide any means for training such models?
My initial understanding was that DeepSort would be able to track all classes recognized by a trained YOLO model. I didn't know that a stand-alone feature extractor was required.
In my experience, if you have really discriminative objects with distinct features then yes! The original DeepSORT's reid model can be borrowed to track those things. But for the best result, you should train your own reid model to suit the task and the classes that you want to track.
GunFire
  • 124
