I am looking to compute the similarity between a large set of vectors during neural network training - a process that is considerably expensive when choosing the wrong metric. So far, I am making use of cosine similarity, but I found that the training gets slowed down by several orders of magnitude because of that. Each batch, I compute batch_size^2 similarities of vectors with 9000 entries containing non-sparse floating-point numbers. Is there an alternative metric to cosine similarity that is much faster but also differentiable?
You probably are not going to get much faster than cosine similarity, the main reason why your calculations are slow is the fact that you execute your operation batch_size$^2$ times which results in a runtime complexity of $O(N^2)$ no matter which metric you choose. However, just to test how much of an improvement you will get by a simpler metric, you might just try the $\infty$-norm: $d(u, v) = \max_i | u_i - v_i |$ or the dot product (i.e. cosine similarity without normalizing the vectors). Just to see whether a simpler metric will actually provide you significant performance improvements.
If you then find out that its not the metric, you can check out Linformer by Wang et al.. As you might know the Transformer architecture also compares N vectors pairwisely. Wang et al. deviced a method how to get memory and time complexity from $O(N^2)$ to $O(N)$. This fits your problem exactly, so maybe it is a good read for you.
- 1,878
- 7
- 13
