I have not found any neural network training methods that recommend manually intervening in the training process while it is happening. However, some experiments I've done seem to show this can be an effective way to speed up training.
For example, once the network has converged on a suboptimal solution, I can have the network focus on particular sections of the training data for awhile, and then switch back to the entire training data to get the network out of the local optima. Gradient descent alone would not be able to do this because while I have the network focus on a subset of the training data the error becomes very large, and then after I release the focus the error drops below the previous local optima value. Gradient descent would not choose to explore an area of the solution space with a significantly higher error than the current region.
Has there been any research into whether these kinds of manual intervention methods can improve over purely automated training?
yters
  • 417
There are two machine learning research fields that are related to your problem: one is curriculum learning, the other is active learning.
Curriculum Learning
The basic idea is to manually design increasingly difficult training tasks that aim to guide the learning of the network towards a better local minima. Say you have a very hard problem, from that you build a curriculum: initially it contains easy and simplified versions of your initial problem, and as the training progresses you switch to a more difficult curriculum, and keep doing this until the difficulty of the training tasks match or even surpasses the one of the original problem.
Such curriculum learning approach has been shown to be beneficial both in deep learning and reinforcement learning problems.
Actually there is much interest in automatically building the curriculum: there are some example of this in the literature, allowing to automatically generate a curriculum according to the network's training performance. This would, at least in principle, solve the issue about how to properly design an effective curriculum which is not trivial in some cases.
References:
Active Learning
The basic idea is to let the training algorithm be helped by a user from time to time.
A use case of this is training data labeling, in which in an online fashion a user labels or even scores data points that are poorly predicted (or classified) by the model. In this regard, a working approach is called DAgger (dataset aggregation) that is used in imitation learning: basically a human manually label data with the best action to take (as the goal of the problem is to learn a policy - so learn best actions that are unknown.)
References:
The answer to your question is: in principle yes, you can speed up training by either manual or automatic guidance of the training, or by manually providing better labels or training data.
Luca Anzalone
  • 3,216
  • 15
