I am currently going through the FastAI course and to practise, I wanted to code a neural network that classifies the FashionMNIST dataset from scratch.
Lately, I've been running into an issue where I get a consistent validation accuracy score of 0.9 sometimes (afer reinitiating my weights and biases), but occasionally it's stuck at 0.1, and does not go anywhere from there.
when it works when it doesn't
I tried to start again from zero multiple times, but can't figure out the issue. I would very much appreciate any help :)
Below is my code:
#hide
!pip install -Uqq fastbook
import fastbook
fastbook.setup_book()
#hide from fastai.vision.all import * from fastbook import *
matplotlib.rc('image', cmap='Greys')
import torchvision.transforms as transforms from torchvision.transforms import ToTensor, Lambda from torch.utils.data import DataLoader from torchvision import datasets import torch import matplotlib.pyplot as plt from torch.nn import CrossEntropyLoss
tfms = transforms.Compose([transforms.ToTensor(), transforms.Normalize((0.1037,), (0.3081))])
training_data = datasets.FashionMNIST( root = 'data', train = True, download = True, transform = tfms, )
train_x = training_data.data.view(-1, 28*28).float()/255
df = pd.DataFrame(train_x[0].view(28,28)) df.style.set_properties(**{'font-size': '6pt'}).background_gradient('Greys')
target_transform = Lambda(lambda y: torch.zeros(10, dtype=float).scatter_(0, y, value = 1)) train_y = torch.stack([target_transform(y) for y in training_data.targets])
dset = list(zip(train_x, train_y)) dl = DataLoader(dset, batch_size=1024, shuffle=True)
testing_data = datasets.FashionMNIST( root='data', train= False, download= True, transform = tfms )
valid_x = testing_data.data.view(-1, 28*28).float()/255 valid_x.shape
valid_y = torch.stack([target_transform(y) for y in testing_data.targets]) valid_y.shape
valid_dset = list(zip(valid_x, valid_y)) valid_dl = DataLoader(dset, batch_size=1024, shuffle = True)
Init params
def init_params(size, std=1.0): return (torch.randn(size)*std).requires_grad_()
weights = init_params((28*28, 10)) biases = init_params(10, 1)
weights.shape, biases.shape, train_x[0].shape
Predict
def linear1(xb): return xb@weights + biases
Calculate loss
def cross_entropy_loss(predictions, targets): predictions = predictions.softmax(dim=1) cross = -targets*torch.log(predictions) return cross.sum(1).mean()
cross_entropy_loss(linear1(train_x[0:40]), train_y[0:40])
Calc grad
def calc_grad(model, xb, yb): preds = model(xb) loss = cross_entropy_loss(preds, yb) loss.backward()
Train epoch
lr = 10 params = weights, biases
def train_epoch(model, params, lr): for xb, yb in dl: calc_grad(model, xb, yb) for p in params: p.data -= p.grad * lr p.grad.zero_()
def batch_accuracy(xb, yb): preds = xb.softmax(dim=1).round() correct = preds.max(1).indices == yb.max(1).indices return correct.float().mean()
def validate_epoch(model): accs = [batch_accuracy(model(xb), yb) for xb, yb in valid_dl] return round(torch.stack(accs).mean().item(), 4)
train_epoch(linear1, params, lr)
validate_epoch(linear1)
for i in range(5): train_epoch(linear1, params, lr) print(validate_epoch(linear1), end= ' ')
print(linear1(valid_x[0:15]).softmax(dim=1).round().max(1).indices == valid_y[0:15].max(1).indices)
DerOeko
  • 13
