Audio data is typically an array with the waveform represented by values from -1 to 1. There are two issues with that:
  1. if all values are inverted, e.g. -1 becomes 1 and 1 becomes -1, the audio doesn't change. But if for example I need to find difference between two audio files, finding per-element difference will say two inverted audio arrays are very different. Realistically two sine waves can easily be shifted relative to each other in a way where they will be inverted to each other.
  2. Related issue is that a wave, for example a 1000hz sound wave, often sounds like a "flat" sound. However in the array it is a literally a sine, and two sines can be shifted which causes inconsistent difference. Ideally a sine should be a sequence of the same number, which is obviously hard to do because audio is usually way more complex than a sine wave.
So what I tried doing, I make a copy of audio files, then I calculate a gradient which hopefully reduces the shifting issues, and then I convert array into absolute value (-1 turns 1). And then I use that copy when comparing audio arrays. When I used that for evaluating how close generated audio is to the original, it caused a lot of low frequencies in the generated audio. When I looked at the waveform, this is because gradient makes low frequencies very quiet since they have small rate of change, so my model doesn't see them. To be clear I am not really sure if gradient is a better match at all. But ideally I'd want something like gradient that doesn't reduce low frequencies.
There is also spectogram - admittedly I haven't looked much into it, but the one I tried - librosa spectogram functionality - takes quite a long time to convert that back into audio. If there is no quick way to do it with 1d arrays, I can use that.
