I need my model to predict $s$ from my data $x$. Additionally, I need the model to not use signals in $x$ that are predictive of a separate target $a$. My approach is to transform $x$ into a representation $\Psi(x)$ such that it's good at predicting $s$ but bad at predicting $a$.
Concretely, let the prediction for $s$ be \begin{equation} \hat{s} = (\Gamma \circ \Psi)(x), \end{equation} and that for $a$ be $$\hat{a} = (\Omega \circ \Psi)(x),$$ where $\Psi, \Gamma, \Omega$ are implemented as MLP layers. Further, let $\ell_s(\Psi,\Gamma)$ and $\ell_a(\Psi,\Omega)$ be the loss functions corresponding to $s$ and $a$, respectively.
The objective thus is to simultaneously
  • minimize $$\ell_s(\Psi,\Gamma)$$ (good at predicting $s$), and
  • maximize $$\min_\Omega \ell_a(\Psi,\Omega) := -f(\Psi)$$ (bad at predicting $a$)
There may not exist a $(\Psi, \Gamma)$ combination that simultaneously achieves both. So the hope is to find something on the Pareto frontier by linearly combining the objectives: \begin{equation} \tag{*}\label{*} \min_{\Psi, \Gamma} \left[ \ell_s(\Psi,\Gamma) + \alpha f(\Psi) \right] = \min_{\Psi, \Gamma} \left[ \ell_s(\Psi,\Gamma) - \alpha \min_\Omega \ell_a(\Psi,\Omega) \right] \end{equation} where $\alpha > 0 $ is a hyperparameter that trades off the two original objectives. enter image description here However, I'm not sure how to train the layers $\Psi, \Gamma, \Omega$ to achieve \eqref{*}. One procedure I could think of is to alternate between
  1. Freeze $\Psi, \Gamma$ and tune $\Omega$ to minimize $\ell_a(\Psi,\Omega)$,
  2. Freeze $\Omega$ and tune $\Psi, \Gamma$ to minimize $\ell_s(\Psi,\Gamma) - \alpha \ell_a(\Psi,\Omega)$
until convergence. Would that work?
It's probably important that both steps be able to tune the learned representation Ψ. Also, that you are always minimizing the combined loss.
You should do:
  1. Freeze Γ and tune Ψ,Ω to minimize ℓ(Ψ,Γ)−ℓ(Ψ,Ω),
  2. Freeze Ω and tune Ψ,Γ to minimize ℓ(Ψ,Γ)−ℓ(Ψ,Ω).
Or, better yet, if Γ and Ω accept the same examples, to just train both in each training step.
Your setup is fine, and sensible. For example, in learning voice conversion, some architectures will have a module adds the following to the objective: This representation of the speech should make it difficult to predict who the speaker is (and thus only model the semantic content of the speech, not speaker style).
These Greek caps seem like a strange notation to me, btw.
