I am trying to retrain ResNet-50 for iris flower classification in tensorflow (TensorFlow version: 2.3.0) using the following code
import tensorflow as tf
import cv2, random
from sklearn.model_selection import train_test_split
from sklearn.metrics import classification_report
from random import shuffle
from IPython.display import SVG
import numpy as np # linear algebra
import pandas as pd
import shutil
import matplotlib.pyplot as plt
%matplotlib inline
from IPython.display import Image, display
import os
print(os.listdir("./iris recognition/flowers"))
labels = os.listdir("./iris recognition/flowers") num_classes = len(set(labels)) IMAGE_SIZE= 224
Create model
model = tf.keras.Sequential() model.add(tf.keras.applications.ResNet50(include_top=False, weights='imagenet')) model.add(tf.keras.layers.GlobalAveragePooling2D()) model.add(tf.keras.layers.Dropout(0.5)) model.add(tf.keras.layers.Dense(num_classes, activation='softmax'))
Do not train first layer (ResNet) as it is already pre-trained
model.layers[0].trainable = False
Compile model
from tensorflow.python.keras import optimizers
sgd = optimizers.SGD(lr = 0.01, decay = 1e-6, momentum = 0.9, nesterov = True) model.compile(optimizer='adam', loss='categorical_crossentropy', metrics=['accuracy']) model.summary() train_folder = './iris recognition/flowers'
image_size = 224 data_generator = tf.keras.preprocessing.image.ImageDataGenerator(preprocessing_function=tf.keras.applications.resnet50.preprocess_input, horizontal_flip=True, width_shift_range=0.2, height_shift_range=0.2, validation_split=0.2)# set validation split
train_generator = data_generator.flow_from_directory( train_folder, target_size=(image_size, image_size), batch_size=10, class_mode='categorical', subset='training' ) validation_generator = data_generator.flow_from_directory( train_folder, target_size=(image_size, image_size), batch_size=10, class_mode='categorical', subset='validation' )
NUM_EPOCHS = 70 EARLY_STOP_PATIENCE = 5 from tensorflow.python.keras.callbacks import EarlyStopping, ModelCheckpoint
cb_early_stopper = EarlyStopping(monitor = 'val_loss', patience = EARLY_STOP_PATIENCE) cb_checkpointer = ModelCheckpoint(filepath = './working/best.hdf5', monitor = 'val_loss', save_best_only = True, mode = 'auto') import math
fit_history = model.fit( train_generator, steps_per_epoch=10, validation_data=validation_generator,
validation_steps=10,
epochs=NUM_EPOCHS,
callbacks=[cb_checkpointer, cb_early_stopper])
model.load_weights("./working/best.hdf5")
I tried to change the number of epochs , steps_per_epoch and validation_steps however the model accuracy does not improved as shown in figure1 figure2
After trying several essais while changing batch size from 32, 64 and 128.For each essai I tried with and without using :
  • steps_per_epoch=10.
  • sgd = optimizers.SGD(lr = 0.01, decay = 1e-6, momentum = 0.9, nesterov = True)
The best accuracy I achieved is 72.29% in which the training was the most stable which was when using batch size=128 as shwon in figure3
Any suggestions please?!
root
It looks like you're defining an optimizer in the line sgd = optimizers.SGD(lr = 0.01, decay = 1e-6, momentum = 0.9, nesterov = True) and then not using it, since you compile the model with optimizer='adam'. So changing any of the sgd parameters, or even commenting out the line, changes nothing for your model.
you'll need to change to model.compile(optimizer=sgd, loss='categorical_crossentropy', metrics=['accuracy']) to use the sgd optimizer object in the model.
Kroshtan
  • 259
