I am working on a project that requires me to identify a product on a grocery shelf. For that, I am trying to use test recognition and localization to spot a product.
I tried Easy OCR and tesseract OCR because they are giving me accurate results, but it takes a lot of time to process the image
  1. Easy OCR takes about 7 seconds to process one image.
  2. Keras OCR takes about 42 seconds.
I followed this post to implement the code: https://www.kaggle.com/code/odins0n/keras-ocr-vs-easyocr-vs-pytesseract
I am running this on my laptop with NVIDIA GeForce RTX 3050 GPU. Is this expected behavior? Is there any way to improve the speed?
Suresh Nayak
  • 31
I think currently you are using CPU for detection and Recognition try installing the cuda to use GPU
pip install torch==1.13.1+cu117 torchvision==0.14.1+cu117 torchaudio==0.13.1 --extra-index-url https://download.pytorch.org/whl/cu117
This will improve speed by around 10X.
If you further want to increase the speed of the detection and recognition then:
Try using https://github.com/NVIDIA-AI-IOT/scene-text-recognition
It will further increase the speed of detection by 2X and for recognition by 5X.
Hiren Namera
  • 785
  • 20
EasyOCR should not be that slow using a GPU, have you installed the CPU version of PyTorch?
If you have a CPU version of PyTorch in the local cache you will need to do the following
uninstall the CPU version of pytorch
pip uninstall torch<br>
install the GPU version, don't use the local cache
pip install torch --extra-index-url https://download.pytorch.org/whl/cu116 --no-cache-dir<br>
If you do a "pip list", you should see, which are the GPU versions
torch                          1.13.1+cu116<br>
torchaudio                     0.13.1+cu116<br>
torchvision                    0.14.1+cu116<br>
I hope this helps.
Hiren Namera
  • 785
  • 20
