I am using training an image classification model using the pre-trained mobile network. During training, I am seeing very high values (more than 70%) for Accuracy, Precision, Recall, and F1-score on both the training dataset and validation dataset. enter image description here enter image description here For me, this is an indication that my model is learning fine.
But when I checked these metrics on an Unbatched training and Unbatched Validation these metrics are very low. Even are then on 1%.
Unbatched dataset means I am not taking calculating these metrics over batches and taking the average of metrics to calculate the final metrics which is what Tensorflow/Keras does during model training.
I am unable to find out what is causing this Behaviour. Please help me understand what is causing this difference and how to ensure that results are consistent on both, i.e. a minor difference is acceptable.
Code that I used for evaluating metrics
def test_model(model, data, CLASSES, label_one_hot=True, average="micro",
                threshold_analysis=False, thres_analysis_start_point=0.0,
                thres_analysis_end_point=0.95, thres_step=0.05, classwise_analysis=False,
                produce_confusion_matrix=False):
    images_ds = data.map(lambda image, label: image)
    labels_ds = data.map(lambda image, label: label).unbatch()
    NUM_VALIDATION_IMAGES = count_data_items(tf_records_filenames=data)
    cm_correct_labels = next(iter(labels_ds.batch(NUM_VALIDATION_IMAGES))).numpy() # get everything as one batch
    if label_one_hot is True:
        cm_correct_labels = np.argmax(cm_correct_labels, axis=-1)
    cm_probabilities = model.predict(images_ds)
    cm_predictions = np.argmax(cm_probabilities, axis=-1)
warnings.filterwarnings('ignore')
overall_score = f1_score(cm_correct_labels, cm_predictions, labels=range(len(CLASSES)), average=average)
overall_precision = precision_score(cm_correct_labels, cm_predictions, labels=range(len(CLASSES)), average=average)
overall_recall = recall_score(cm_correct_labels, cm_predictions, labels=range(len(CLASSES)), average=average)
# cmat = (cmat.T / cmat.sum(axis=1)).T # normalized
# print('f1 score: {:.3f}, precision: {:.3f}, recall: {:.3f}'.format(score, precision, recall))
overall_test_results = {'overall_f1_score': overall_score, 'overall_precision':overall_precision, 'overall_recall':overall_recall}
if classwise_analysis is True:
    label_index_dict = get_index_label_from_tf_record(dataset=data)
    label_index_dict = {k:v for k, v in sorted(list(label_index_dict.items()))}
    label_index_df = pd.DataFrame(label_index_dict, index=[0]).T.reset_index().rename(columns={'index':'class_ind', 0:'class_names'})
    # Class wise precision, recall and f1_score
    classwise_score = f1_score(cm_correct_labels, cm_predictions, labels=range(len(CLASSES)), average=None)
    classwise_precision = precision_score(cm_correct_labels, cm_predictions, labels=range(len(CLASSES)), average=None)
    classwise_recall = recall_score(cm_correct_labels, cm_predictions, labels=range(len(CLASSES)), average=None)
    ind_class_count_df = class_ind_counter_from_tfrecord(data)
    ind_class_count_df = ind_class_count_df.merge(label_index_df, how='left', left_on='class_names', right_on='class_names')
    classwise_test_results = {'classwise_f1_score':classwise_score, 'classwise_precision':classwise_precision,
                    'classwise_recall':classwise_recall, 'class_names':CLASSES}
    classwise_test_results_df = pd.DataFrame(classwise_test_results)
    if produce_confusion_matrix is True:
        cmat = confusion_matrix(cm_correct_labels, cm_predictions, labels=range(len(CLASSES)))
        return overall_test_results, classwise_test_results, cmat
    return overall_test_results, cmat
warnings.filterwarnings('always')
learner
  • 151
After spending many hours, I found the issue was due to the shuffle function. I was using the below function to shuffle, batch and prefetch the dataset.
def shuffle_batch_prefetch(dataset, prefetch_size=1, batch_size=16,
                            shuffle_buffer_size=None,
                            drop_remainder=False,
                            interleave_num_pcall=None):
if shuffle_buffer_size is None:
    raise ValueError("shuffle_buffer_size can't be None")
def shuffle_fn(ds):
     return ds.shuffle(buffer_size=shuffle_buffer_size, seed=108)
dataset = dataset.apply(shuffle_fn)
dataset = dataset.batch(batch_size, drop_remainder=drop_remainder)
dataset = dataset.prefetch(buffer_size=prefetch_size)
return dataset
Part of the function that causes the problem
def shuffle_fn(ds):
I removed the shuffle part and metrics are back as per the expectation. Function after removing the shuffle part
    return dataset
Results after removing the shuffle part enter image description here
I am still not able to understand why shuffling causes this error. Shuffling was the best practice to follow before training your data. Although, I have already shuffled training data during data read time.
I have also posted the same issue at SO thinking that it might be related to some coding error.
learner
  • 151
