I have finished implementing an Asynchronous Advantage Actor-Critic (A3C) agent for TensorFlow (gpu). By using a single RMSprop optimizer with shared statistics. To do so, a central controller holds both the Global Network (ActorCriticModel) and the Optimizer. Workers, to update the global network, need to communicate gradients to the Controller, while receiving back the updated model weights. It works decently: despite there might be some errors in the code, it still achieves the results pretty fast. Each Worker is a thread on its own.
class Worker(Thread):
Problem is Workers need to extend the Thread class while I would like to use heavy Processes (from multiprocessing) instead (Queues used in the following snippet of code are imported from the multiprocessing class).
class Controller:
def __init__(self, **kwargs):
self.terminated_workers = 0
self.env_name = kwargs["env_name"]
self.available_actions = kwargs["available_actions"]
self.action_size = len(self.available_actions)
self.env = make_env(kwargs, env_name=self.env_name)
self.state_shape = self.env.observation_space.shape
self.number_of_workers = kwargs["number_of_workers"]
self.workers = []
self.controller_queue = Queue()
self.worker_queues = []
# Initialization of threads
for i in range(self.number_of_workers):
worker_queue = Queue()
self.worker_queues.append(worker_queue)
updater = GlobalUpdater(self.controller_queue, worker_queue)
worker = Worker(i, updater, self.state_shape, kwargs)
self.workers.append(worker)
# Only import tensorflow after heavy Process initialization
import tensorflow as tf
self.global_model = ActorCriticModel(self.state_shape, self.action_size)
self.opt = tf.keras.optimizers.RMSprop(
learning_rate=kwargs["lr_schedule"],
rho=kwargs["rho"],
centered=kwargs["centered"],
clipvalue=kwargs["clipvalue"]
As soon as i change the Worker to extend Processes instead of threads, I get the following message for every worker instantiated:
F tensorflow/stream_executor/cuda/cuda_driver.cc:152] Failed setting context: CUDA_ERROR_NOT_INITIALIZED: initialization error
Technically, since multiple methods of the Worker class need to use tensorflow, the library is imported statically, before declaring the Worker class, as follows:
class Worker(Process):
I'm using Linux and the libraries' versions are:
- TensorFlow: 2.9.1
- CUDA: 11.2.2-1
- cuDNN: 8.1.1.33-1+cuda11.2
I tried every other solution I found online, including setting mp.set_start_method('spawn') and trying to postpone as much as i can the import of the tensorflow library, so to postpone as much as possible the heavy process initialization but nothing seems to work. How would you approach this problem? Do you have any idea on how to solve it? Thanks in advance.
self.tfor useglobal tf? Also you should use gpu memory growth, otherwise the first process will occupy the whole space on the GPU. – Chillston Jul 12 '22 at 18:58self.tfis not compatible with the code (as I'm using the @tf.function). – Lyn Cassidy Jul 12 '22 at 21:44multiprocessing.set_start_method('spawn', force=True), importing TensorFlow within the spawned process upon creation and puttingglobal tfright after the import. And it actually works. You're a beast! I've spent months trying to figure this out, it's a pity this post will be removed as I think a lot of people would actually need to see this. – Lyn Cassidy Jul 12 '22 at 21:52
