I'm using this domain/problem with the fast-downward planner like this:
./fast-downward.py --plan-file plan.out ../test_domain.pddl ../test_problem.pddl
The issue here is that the output.sas contains hundreds of thousands of lines without a clear reference to the solution plan!
Here is the full output log of the planner:
$ ./fast-downward.py --plan-file plan.out ../test_domain.pddl ../test_problem.pddl
INFO     planner time limit: None
INFO     planner memory limit: None
INFO Running translator. INFO translator stdin: None INFO translator time limit: None INFO translator memory limit: None INFO translator command line string: /usr/bin/python3 /media/belal/WD//Planning/downward/builds/release/bin/translate/translate.py ../test_domain.pddl ../test_problem.pddl --sas-file output.sas Parsing... Parsing: [0.000s CPU, 0.001s wall-clock] Normalizing task... [0.000s CPU, 0.000s wall-clock] Instantiating... Generating Datalog program... [0.000s CPU, 0.000s wall-clock] Normalizing Datalog program... Normalizing Datalog program: [0.000s CPU, 0.001s wall-clock] Preparing model... [0.000s CPU, 0.000s wall-clock] Generated 9 rules. Computing model... [0.000s CPU, 0.000s wall-clock] 73 relevant atoms 28 auxiliary atoms 101 final queue length 157 total queue pushes Completing instantiation... [0.000s CPU, 0.001s wall-clock] Instantiating: [0.000s CPU, 0.003s wall-clock] Computing fact groups... Finding invariants... 5 initial candidates Finding invariants: [0.000s CPU, 0.001s wall-clock] Checking invariant weight... [0.000s CPU, 0.000s wall-clock] Instantiating groups... [0.000s CPU, 0.000s wall-clock] Collecting mutex groups... [0.000s CPU, 0.000s wall-clock] Choosing groups... 4 uncovered facts Choosing groups: [0.000s CPU, 0.000s wall-clock] Building translation key... [0.000s CPU, 0.000s wall-clock] Computing fact groups: [0.000s CPU, 0.001s wall-clock] Building STRIPS to SAS dictionary... [0.000s CPU, 0.000s wall-clock] Building dictionary for full mutex groups... [0.000s CPU, 0.000s wall-clock] Building mutex information... Building mutex information: [0.000s CPU, 0.000s wall-clock] Translating task... Processing axioms... Simplifying axioms... [0.000s CPU, 0.000s wall-clock] Translator axioms removed by simplifying: 0 Computing negative axioms... [0.000s CPU, 0.000s wall-clock] Processing axioms: [0.000s CPU, 0.000s wall-clock] Translating task: [0.000s CPU, 0.001s wall-clock] 24 effect conditions simplified 0 implied preconditions added Detecting unreachable propositions... 0 operators removed 0 axioms removed 2 propositions removed Detecting unreachable propositions: [0.000s CPU, 0.000s wall-clock] Reordering and filtering variables... 6 of 6 variables necessary. 4 of 6 mutex groups necessary. 24 of 24 operators necessary. 0 of 0 axiom rules necessary. Reordering and filtering variables: [0.000s CPU, 0.000s wall-clock] Translator variables: 6 Translator derived variables: 0 Translator facts: 16 Translator goal facts: 2 Translator mutex groups: 4 Translator total mutex groups size: 12 Translator operators: 24 Translator axioms: 0 Translator task size: 204 Translator peak memory: 31884 KB Writing output... [0.000s CPU, 0.000s wall-clock] Done! [0.000s CPU, 0.007s wall-clock] translate exit code: 0
INFO Running search (release). search needs --alias, --portfolio, or search options
Can you please tell me how can I interpret the generated plan?
Bilal
  • 105
Fun domain!
You shouldn't have to be parsing the FD output for the plan. Just use --plan-file plan.out as a command-line option to write the plan to the plan.out file. Chances are that it's already creating a file for you locally and you may not have noticed.
haz
  • 256
