In general, there are two types of transition functions in reinforcement learning. Mathematically, they are as follows
#1: Stochastic state transition function:
$$T : S \times A \times S \rightarrow [0, 1]$$
#2: Deterministic state transition function:
$$T : S \times A \rightarrow S$$
Is it possible to make the transition function change as the game progress? Or is it impossible to assume such a transition function as it cannot qualify to be a function?
Or in other words, I may want to introduce something as follows:
#3: Dynamic state transition function:
$$T : S \times A \times X \rightarrow S$$
where $X$ is some continuous set.
nbro
  • 42,615
  • 119
  • 217
hanugm
  • 4,102
  • 29
  • 63
Yes, the normal way to do this would be to make the current time or time step $t$ part of the state $s$, so that equation 1 or 2 applies as normal. Similar applies if by "as the game progresses" that there is some other measure of progression such as how much the agent has scored so far, make that measure part of the state. Unless for some reason you do not want to allow the agent to track this extra pogression effect that impacts the behaviour - in which case you would typically consider the environment to be a partially observable MPD or POMDP.
Your equation 3 doesn't define a dynamic environment, but a parametric one. You have added the parameter $x$ to the normal MDP transition function. What that means depends critically on how the parametrisation of the transition function $T$ works in detail, and what you then do with the parameter $x$. Different modes of changing $x$ (plus different sensitivies to $x$ in the transtion function $T$) correspond to different classes of environment in the RL literature.
Here are some examples:
  • If $x$ is sampled from set $X$ once, and once only, your equation 3 reduces to equation 2. Sampling $x$ corresponds to selecting an environment to learn.
  • If $x$ is known/accessible to the agent, then regardless of how it is chosen, your true state is $s+x$ and equation 3 reduces to either equation 1 or equation 2 depending on how the $x$ part of $s+x$ transitions.
  • If $x$ is sampled independently from any other variable, on each and every time step, then equation 3 reduces to equation 1. Sampling $x$ in this way corresponds to choosing a random transition (from whatever is allowed by the nature of $T$) based on state and action.
  • If $x$ is sampled infrequently (less than once per episode) or evolves in a slow fashion (when combined with how T works, changes happen to effective transition rules less than once per episode), then you may have a non-stationary environment. This is typically addressed by continuously learning agents - a good example of an RL method written specifically to address this is DynaQ+.
  • If $x$ is sampled (or even fixed) at the start of the episode and evolves either independently or depending on state $s$ and action $a$ (plus any random changes), and the agent is not allowed to know $x$, then you have a POMDP. How solvable that is depends on how easy it is for the agent to allow for and learn what it can about $x$ - you may specifically need a POMDP solver. Knowing $X$ and the transition rules for $x$ may make a POMDP solver more feasible in practice.
    • Instead of using $s$ and $x$, literature on POMDPs would typically use $s$ for state (equivalent to your $s, x$ concatenated) and $o$ for the agent's observation (equivalent to your $s$)
So, in summary, there isn't really a class of "dynamic" environments in RL studied under that name. Your idea might fit into one or more of several other well-studied concepts in RL instead.
Neil Slater
  • 33,739
  • 47
  • 66
