I have a question about the Grad-CAM++ paper. I do not understand how the following equation (10) for the alphas is obtained: $$ \alpha_{ij}^{kc} = \frac{\frac{\partial^2 Y^c}{(\partial A_{ij}^k)^2}} {2\frac{\partial^2 Y^c}{(\partial A_{ij}^k)^2} + \sum_{ab} A_{ab}^k \{ \frac{\partial^3 Y^c}{(\partial A_{ij}^k)^3} \}} \qquad (10) $$ I found various issues with the derivation, here I will focus on the step from equation (7) to (8).
Equation (7) without the relu function is: $$ Y^c = \sum_k \Bigl( \Bigl\{ \sum_{a,b} \alpha_{ab}^{kc} \cdot \frac{\partial Y^c}{\partial A_{ab}^k} \Bigr\} \Bigl[ \sum_{i,j} A_{ij}^k \Bigr] \Bigr) \qquad (7) $$ Here $Y^c$ is supposed to be a function of the $A_{ij}^k$, and $\alpha_{ab}^{kc}$ are unknowns to be determined.
The next step consists of computing the partial derivative of (7) w.r.t. $A_{ij}^{kc}$, which according to the paper yields equation (8): $$ \frac{\partial Y^c}{\partial A_{jk}^k} = \sum_{a,b} \alpha_{ab}^{kc} \cdot \frac{\partial Y^c}{\partial A_{ab}^k} + \sum_{a,b} A_{ab}^k \Bigl\{ \alpha_{ij}^{kc} \cdot \frac{\partial^2 Y^c}{(\partial A_{jk}^k)^2} \Bigr\} \qquad (8) $$ However, when I did the computation myself I got the following: $$ \frac{\partial Y^c}{\partial A_{ij}^k} = \sum_{a,b} \alpha_{ab}^{kc} \cdot \frac{\partial Y^c}{\partial A_{ab}^k} + \sum_l \Bigl(\Bigl[\sum_{u,v} A_{uv}^l \Bigr] \Bigl\{ \sum_{a,b} \alpha_{ab}^{lc} \cdot \frac{\partial^2 Y^c}{\partial A_{ij}^k \partial A_{ab}^l} \Bigr\} \Bigr) \qquad (8') $$ Note the extra sum, and the cross-derivatives.
What is right, (8) or (8')?
nbro
  • 42,615
  • 119
  • 217
mlerma54
  • 141
After some reflection I noticed that the actual final expression should contain derivatives of the alphas w.r.t. $A_{ij}^k$ too, because the alphas cannot be constants that do not depend on $A_{ij}^k$. So, the equation becomes: $$ \frac{\partial Y^c}{\partial A_{ij}^k} = \sum_{a,b} \alpha_{ab}^{kc} \cdot \frac{\partial Y^c}{\partial A_{ab}^k} + \sum_l \Bigl(\Bigl[\sum_{u,v} A_{uv}^l \Bigr] \Bigl\{ \sum_{a,b} \alpha_{ab}^{lc} \cdot \frac{\partial^2 Y^c}{\partial A_{ij}^k \partial A_{ab}^l} \Bigr\} \Bigr) + \sum_l \Bigl( \Bigl[\sum_{u,v} A_{uv}^l\Bigr] \Bigl\{ \sum_{a,b} \frac{\partial \alpha_{ab}^{lc}}{\partial A_{ij}^k} \cdot \frac{\partial Y^c}{\partial A_{ab}^l} \Bigr\} \Bigr) $$ More details in the appendix of this document.
I believe this is the final answer to my question.
mlerma54
  • 141
