I have a question about how to update the Q-function in Q-learning and SARSA. Here (What are the differences between SARSA and Q-learning?) the following updating formulas are given:
Q-Learning
$$Q(s,a) = Q(s,a) + \alpha (R_{t+1} + \gamma \max_aQ(s',a) - Q(s,a))$$
SARSA
$$Q(s,a) = Q(s,a) + \alpha (R_{t+1} + \gamma Q(s',a') - Q(s,a))$$
How can we calculate the $Q(s', a')$ in both SARSA and Q-learning for updating the Q-function? After having taken an action $a$ at state $s$, we get the reward $r$, which we can observe. But we cannot observe $Q(s',a')$ from the environment as far as I see it.
Can anyone maybe think about a comprehensive example where you can see how it is done (or a link to a website)?
nbro
  • 42,615
  • 119
  • 217
PeterBe
  • 276
  • 14
It seems that your problem is that you think that we must know the true value of $Q(s', a')$ in order to perform the SARSA update. This is not the case! SARSA is a reinforcement learning algorithm, not a supervised learning algorithm (although you can also view RL as a form of SL).
If you are familiar with supervised learning (SL), then you know that, to train a model, you need the ground-truth labels. The typical SL example is that of binary classification of dogs and cats. So, you are given an image of a dog or cat $x$, you pass it to your neural network $f$, which produces a prediction $\hat{y} = f(x)$. Now, if $x$ is a dog but $\hat{y}$ is cat, the neural network $f$ made a mistake. So, we need to change the weights of this model so that $\hat{y} = \text{dog}$ when $x$ is an image of a dog (of course, this reasoning also applies to the case when $x$ is an image of a cat). A typical way to solve this problem in SL is to use a loss function that computes some notion of distance between $\hat{y}$ (the prediction) and $y$ (the true label). The usual loss function, in this case, is the binary cross-entropy, but you don't need to know the details now.
In reinforcement learning, you don't really have ground-truth labels, but you have experience, which is just the tuples $\langle s_t, a_t, r_{t+1}, s_{t+1} \rangle $, where
  • $s_t$ is the state of the agent/environment at time step $t$
  • $a_t$ is the action that the agent takes at time step $t$ in state $s_t$
  • $r_{t+1}$ is the reward the agent receives after having taken action $a_t$ in $s_t$; this reward indicates how good that action is, but it doesn't tell whether you took the correct/optimal (or ground-truth) action or not (this is the main difference between reinforcement learning and supervised learning!)
  • $s_{t+1}$ is the state the agent ends up in after having taken $a_t$ in $s_t$.
Now, in reinforcement learning, there are many problems that you may want to solve. However, the main goal of an RL agent is to maximize expected reward in the long run (known also as expected return), so you could say that your objective function is $$\mathbb{E} \left[ \sum_{t=0}^\infty R_t \right],$$ where $G = \sum_{t=0}^\infty R_t$ is the so-called return (i.e. the cumulative reward or reward in the long run). The goal is to maximize this expectation.
In practice, what you do is ESTIMATE a so-called (state-action or just action) value function. In the case of SARSA, it's defined as $q: \mathcal{S} \times \mathcal{A} \rightarrow \mathbb{R}$, where $\mathcal{S}$ and $\mathcal{A}$ are respectively the set of states and actions of the environment (aka MDP).
Why do you want to estimate a value function? In the case of $q$ (so SARSA and Q-learning), $q(s, a)$, for some $s \in \mathcal{S}$ and $a \in \mathcal{A}$, is defined as the expected cumulative reward that you will get from taking action $a$ in the state $s$. So, if you know that you will get more reward by taking action $a_1$ rather than action $a_2$ in state $s$, then $q(s, a_1) > q(s, a_2)$, so you will take action $a_1$ when in state $s$. In fact, you can also define $q(s, a)$ as follows $q(s, a) = \mathbb{E}\left[ G \mid s, a \right]$, where $G$ is our cumulative reward, aka return (for simplicity, I ignore a few details).
HOWEVER, we do not (usually) know $q$. That's why we need Q-learning and SARSA, i.e. to estimate the state-action value function. So, in SARSA, you know $s'$ and $a'$ (read the pseudocode!), but we do not know the true value of $q(s', a')$. So, you say, but then why do we use it in the update of SARSA?
The reason is: initially, SARSA uses possibly wrong estimates of $q$ to learn $q$ itself. We denote these estimates with the capital letter $Q$. So, we don't know the true value of $a'$ in $s'$. Or, more precisely, at the beginning of SARSA, if $q$ is implemented as a 2d array (or matrix), then $Q[s', a']$ is not a good estimate of the true value of $a'$ in state $s'$, i.e. $q(s', a')$. In other words, $Q[s', a'] \approx q(s', a')$.
Now, you ask: why can we use a possibly wrong estimate, $Q(s', a')$, to compute $Q(s, a)$ (another estimate)? The idea of using possibly wrong estimates of the state-value function to update other estimates of the value function is present in all temporal-difference algorithms (including Q-learning): this is called bootstrapping. However, the specific reason why tabular SARSA converges to the true estimates is a different (although related) story (more info here).
Now, if you didn't understand this answer, then you really need to pick up a book and read it carefully from the beginning. It takes time to understand RL at the beginning, but then it becomes easy. The most common textbook for RL is Reinforcement Learning: An Introduction by Sutton and Barto. You can find other books here.
nbro
  • 42,615
  • 119
  • 217
