I made a simple expert system using ES-Builder. Please click the link to view it. ES-Builder is a web-based expert system shell. There is a tree-based knowledge representation. In ES builder, User Interfaces are also automatically designed. They generate a link as I have shared above and anyone can access it and can use it.
But when I try other ES shells such as JESS, CLIPS & PyKE, I only noticed that there we have to write facts and rules and the program is run on command line upon consulting the Expert System. There is no UI like in ES-Builder.
My question is, is there any way to build UI to the expert systems created by CLIPS/JESS? Or else should I create a web application using another framework like Spring, DotNet, and integrate it with the knowledge base created with CLIPS/JESS?
(I am a bit confused, because according to what I have learned: if we use an expert system shell then we need not program it using languages (such as Prolog). Because the User Interfaces and Inference Engine is already there. What we are remained to do is just to build the knowledge base. Similar to ES builder UI is auto built.)
Thank you very much for the support! If the question is confusing, I am happy to modify it in a more understandable manner.
Most old school Expert System tools are text based and based on If/Then rules going forwards or backwards (chaining)
Some have graphical front ends (such as VisiRule (https://www.visirule.co.uk/), XpertRule, etc)
Some have now repositioned themselves as Business Rules tools and most of these have GUIs (InRule, Actico etc)
CliveS
