I know the encoder is variational posterior $q_{\phi}(\mathbf{z} \mid \mathbf{x})$.
I also know that the decoder represents the likelihood: $p_{\theta}(\mathbf{x} \mid \mathbf{z})$.
My question is about the prior $\mathrm{p}(\mathbf{z})$.
I know ELBO can be written as:
$$E_{q_{\phi}(\mathbf{z} \mid \mathbf{x})}[\log (p_{\theta}(\mathbf{x} \mid \mathbf{z}))]-\mathrm{D}_{\mathrm{KL}}( q_{\phi}(\mathbf{z} \mid \mathbf{x}) \| \mathrm{p}(\mathbf{z})) \leq \log (p_{\theta}( \mathbf{x}))$$
And for the VAE, the variational posterior is
$$ q_{\boldsymbol{\phi}}(\mathbf{z} \mid \mathbf{x}^{(i)})= \mathcal{N}( \boldsymbol{\mu}^{(i)}, \boldsymbol{\sigma}^{2(i)} \mathbf{I}),$$
and prior is
$$ \mathrm{p}(\mathbf{z})=\mathcal{N}( \boldsymbol{0}, \mathbf{I}).$$
So
$$\mathrm{D}_{\mathrm{KL}}\left(\mathrm{q}_{\Phi}(\mathbf{z} \mid \mathbf{x}) \| p_{z}(\mathbf{z})\right)=\frac{1}{2} \sum_{j=1}^{J}\left(1+\log \left(\sigma_{j}^{2}\right)-\sigma_{j}^{2}-\mu_{j}^{2}\right)$$
That's one way I know the prior plays a role, in helping determine part of the loss function.
Is there any other role that the prior plays for the VAE?
a12345
  • 243
The prior $p(z)$ is assumed as part of the problem formulation. A typical case is where $z$ is a vector of iid normal random variables. The ELBO involves a regularization term which encourages $q(z \, | \, x)$ to have a similar distribution to $p(z)$ (the way you've written it, that's the KL term). Thus $q(z \, | \, x)$ will end up having a similar shape to $p(z)$. For example, again assuming $z$ is a vector of iid normals, if you plot samples of $z$ drawn from $q(z \, | \, x)$ you will find it has a roughly spherical shape. If you scroll down to the [16] code block and look at the figure you'll see what I mean. The figure is plotting samples of $z$, colored according to what $x$ is (MNIST example). This is just some random figure I found, and I don't endorse this code, but the image is what you'd expect to see.
The way we end up with a distribution $p(x, z)$ is by using the prior. We sample $z$ according to $p(z)$; we've trained the decoder $p(x \, | \, z)$, and by definition $p(x, z) = p(x \, | \, z) p(z)$.
Taw
  • 1,321
