I need to build a hand detector that recognizes the chord played by a hand on a guitar.
I read this article Static Hand Gesture Recognition using Convolutional Neural Network with Data Augmentation that looks like what I need (hand gesture recognition).
I think my task is (from my point of view) a little more difficult than that in the paper, because I think it is more difficult to distinguish between two chords than between a punch and a palm.
What I don't understand clearly is how to choose the best parameters for this more complex task: is it better to have more/less convolutional layers? A higher or lower number of poolings? Max or avg pooling?
The input will be more or less like this one:
Input
There will be a first net (MobileNetV2 trained on EgoHands) that will find the bounding box, crops the image and then passes the saturated blending between the original one and Frei&Chen edges to the second net (unfortunately I don't have a processed picture yet, I will post an example as soon as I get it)
nbro
  • 42,615
  • 119
  • 217
Deffo
  • 83
The ideal hyperparameters is usually dependent on your dataset and will differ on a case by case basis. Go for trial and error to determine the hyperparameters that works best for you.
Few research papers similar to your use case is listed below.
Archana David
  • 287
