We generally encounter the following statement several times
The input vector is first fed into a fully connected layer......
Since linear activation functions, such as identity function, can so considered as an activation functions, a fully connected layer can be considered just as an Affine transformation if the fully connected layer uses linear activation function.
So, in theory, a fully connected layer can refer to the following
  1. Just an affine transformation
  2. Affine transformation followed by a nonlinear activation function
Do authors generally choose to use "fully connected layer" for case 2 only or for both cases 1 and 2?
hanugm
  • 4,102
  • 29
  • 63
Yes, typically, a fully connected layer is an affine transformation, which can or not be followed by a non-linear activation function, but, in many (if not most) cases, it's followed by a non-linearity, such as ReLU, sigmoid, or tanh (an exception is when you do regression), which is what makes the neural network be able to approximate non-linear/complicated functions.
nbro
  • 42,615
  • 119
  • 217
