10
Negative results occur frequently in AI/ML research (and perhaps in other domains too). Most of the time, these results are not published. This is mostly because your typical AI/ML conference doesn't accept such papers.
However, are there any venues to publish these results? I believe these results can be still useful to look at before you delve into a certain project so that you'd at least know what approaches don't work.
As an example venue, there seems to be PerFail workshop from the pervasive computing domain. So, is there something similar for AI/ML?
nbro
  • 42,615
  • 119
  • 217
SpiderRico
  • 1,040
  • 18
This workshop that has been at NeurIPS for several years is for things you think aught to work, but don't: https://i-cant-believe-its-not-better.github.io/
Carl
  • 141
Such results should probably be put on arXiv. It's moderated, but there's no peer-review process, so if your goal is to just make useful information available, then this is your best bet.
Alexander Wan
  • 1,409
