I'm trying to solve a linear programming problem using reinforcement learning. The linear programming problem is:
\begin{array}{ll} \text{maximize}_x & C* x \\ \text{subject to}& A*x \le b\\ & x_i \in [0,1],\ where \ i=1,2,3,... \end{array}
For instance: \begin{array}{ll} C &= [1 \; 2 \;3 \;4]\\ x &= [x1; x2; x3; x4]\\ A &= [2 \;3 \;4 \;5]\\ b &= 10\\ \end{array}
I've tried to use the DDPG algorithm to train in MATLAB but the result is not good. Any suggestions for this problem, and is it possible to do so, thanks?
Straight theoretical answer:
In theory, yes, it is possible to model this problem as a Reinforcement Learning. But in practice, RL is not the most suitable approach for a simple linear maximization with a boundary. For instance, you could use a Lagrangian.
Practical analysis on your specific problem
In this specific example, you have 1 single constrain: $\sum_{i} a_i x_i \le b$, for an $n$ degree equation (n = size of $X$). So you might also want to add another boundary, like: all $X > 0$. Otherwise your solution will diverge:
  • $C = [1 2 3 4];$
  • $X = [x_1; x_2; x_3; x_4];$
  • $A = [2 3 4 5];$
  • $b = 10$
Simple example of divergent solution:
$X = lim_{k=\infty} [-3k, 0,0, k]$
Gives you: $C*X= -3k + 0+0+4k = k$ ✅ Maximum possible reward for $lim_{k=\infty}$
Constrained by $A*X = -6k + 0 + 0 +5k = -k \le 10$ ✅ Minimum possible boundary for $lim_{k=\infty}$
Edit after adding $x_i \in [0,1] $ constraints:
You have described the simplest version of Knapsack Problem, where we can split items in fractions.
For this problem, the greedy solution is very simple and effective:
Calculate a new weight vector: $W = C/A = [ c_1 / a_1, c_2/a_2, ... ]$, which represents the ratio of value $c_i$ $/$ cost $a_i$ for each index $i$.
Now, to have the best value $C$ for a limited cost $A$, you just need to greedy select the $i$ from the largest ratio $w_i$ and "fill your Knapsack" (by increasing continuously $x_i$) until some boundary is filled:
  • If $x_i\le1$ is reached (you have exhausted all available $x_i$), than proceed to the next best $w_i$.
  • If total boundary $B$ is reached, than you've finished the algorithm and that's a guaranteed best solution.
Andre Goulart
  • 874
  • 25
