I'm using nvidia Transfer Learning Toolkit to detect cars in some video frames.
I found some dataset (for example https://www.jpjodoin.com/urbantracker/dataset.html and https://www.kaggle.com/aalborguniversity/aau-rainsnow) and I noticed that usually parked cars are not labeled, and covered under a mask.
Why shouldn't I add also their labels? It would be easy to label them because they are static objects and I could copy-paste in all labels set. So why in video dataset they are not labelled?
Andre Goulart
  • 874
  • 25
  1. Model architecture:
In machine learning, static image detectors can be is very different from video detectors, as movement plays a big role on the task. So, even when comparing frames the objects are similar, when digesting the video, a model can learn very different things. Maybe adding parked cars to the database increased false positives, mistakenly labeling other static noises as cars.
  1. Business goal:
Why are you labeling cars from security camera, in the first place? What is your goal here? Maybe if you want to know car density in a parking lot, than labeling parked cars is very useful. But if you just need to know traffic flow, than parked cars will be just a distraction, noise from the data. So maybe whoever built the dataset had a different goal in mind.
Andre Goulart
  • 874
  • 25
