In mathematics, there is a proof that the following infinite series converges to a constant irrational number, denoted by $e$, called as Euler's number or Euler's constant or Napier's constant. The value of $e$ lies between 2 and 3.
$$1 + \dfrac{1}{1!} + \dfrac{1}{2!} + \dfrac{1}{3!} + \cdots$$
The natural exponential function, defined as follows, has some interesting properties
$$f: \mathbb{R} \rightarrow \mathbb{R}$$ $$f(x) = e^x$$
It is used in several algorithms and in the definitions of functions like SoftMax. I am interested in knowing the possible mathematical characteristics that lead this function useful in artificial intelligence.
The following are the properties I am aware of. But, I am not sure about how some of them will be useful
  1. Non-linearlity: Activation functions are intended to provide non-linearity. So, it is a candidate for activation functions due to this property. You can check its graph here.
  2. Differentiability: Loss functions used for in back-propagation algorithm need to be differentiable. So, it can be a candidate for usage in loss functions too.
$$\dfrac{d}{dx} e^x = e^x \text{ for all } x \in \mathbb{R}$$
  1. Continuity: I am not sure how this property is useful in algorithms. Intuitively, you can check from graph provided above that it is continuous.
  2. Smoothness: I am not sure how this property is useful in algorithms. But seems useful. The natural exponential function has the smoothness property.
$$\dfrac{d^n}{d^nx} e^x = e^x \text{ for all } x \in \mathbb{R} \text{ and } n \in \mathbb{N}$$.
Are there any other properties like non-linearily, differentiability, smoothness etc., for the natural exponential function that make it superior to use in AI algorithms?
Glorfindel
  • 179
  • 13
hanugm
  • 4,102
  • 29
  • 63
The question must be split in two:
Use in softmax: softmax is based in the concept of cross entropy, logistic regression, logistic function ... . All these concepts includes exponential or logarithmic in its formulation.
Use in activation functions:
  • monotonic: a non-monotonic function will give same output to different inputs, disturbing the concept of distance/error.
  • non-linear: a linear activation function collapses the layer with the next one, thus, it is useless.
  • differentiable: necessary to use back-propagation.
pasaba por aqui
  • 1,313
While all the properties you list are true, the essential parts are the Differentiability and the fact that you build a nice probability distribution from it.
The unnormalized scores the neural network puts out before we apply softmax to them may very well contain negative values. Applying the exponential function is a great way to build a probability distribution from a given vector, disregarding the sign of the values.
tnfru
  • 358
