What is the right way to input continuous, temporal (time-series) data into the Transformer? Assume we're using the basic TransformerBlock here.
Since data is continuous with no tokens, Token embedding can be directly skipped. How about positional encoding? I tried this example, removing Token embedding while keeping positional encoding but ended up with shape-related errors. Skipping both token and positional encoding resulted in a network that runs and trains but results were relatively poor compared to the LSTM benchmark with the same data.
I am unsure if the positional encoding is still needed.
Overall, my question is, what is the proper way to process continuous sequence data, such as time-series, using the Transformer architecture?
nbro
  • 42,615
  • 119
  • 217
meliksahturker
  • 346
Instead of using a token embedding you can use a linear layer. For an input of (10, 5, 4) - (sequence length, batch size, features) you can create a linear layer:
self.embedding_layer = nn.Linear(4, d_model)
Where d_model is the dimension of the input to the transformer.
PositionalEncoding is still needed so as to have a representation of time in the inputs.
src = self.embedding_layer(src)
src = self.pos_encoding_layer(src)
output = self.transformer(src)
Dylan Kerler
  • 313
