The R.S. Sutton and A. G. Barto book says "Often $\mu(s)$ is chosen to be the fraction of time spent in $s$? But then why a discount factor is needed in the continual case?
Discounting is practical when working with discounted rewards but not necessary when working with average rewards.
Why do may need to discount our state distribution with discounted rewards?
Let $\gamma \in [0,1[$ be the discount factor.
Let the discounted state measure be defined as
\mu(s) = \sum_{t=0}^{\infty} \gamma^t \mathbb{P}^\pi(S_t = s)
where $\mathbb{P}^\pi(S_t = s)$ is the probability of being in state $s$ at time $t$.
\int_\mathcal{S} \mu(s) ds = \sum_{s \in \mathcal{S}} \mu(s) = \sum_{s \in \mathcal{S}} \sum_{t=0}^{\infty} \gamma^t \mathbb{P}^\pi(S_t = s) = \sum_{t=0}^{\infty} \gamma^t \sum_{s \in \mathcal{S}} \mathbb{P}^\pi(S_t = s) = \sum_{t=0}^{\infty} \gamma^t = \frac{1}{1-\gamma}
where $\mathcal{S}$ is the state space.
Thus, to be a distribution $\mu$ has to be multiplied by $1 -\gamma$ as in [1].
Note that if $\gamma = 1$, then the total mass of $\mu$ goes to $+\infty$.
The distribution $\mu$ is said improper in this case.
Also remark that,
\mathbb{P}^\pi(S_t = s, A_t = a) = \mathbb{P}^\pi(S_t = s) \mathbb{P}^\pi(A_t = a | S_t = s) = \mathbb{P}^\pi(S_t = s) \pi(a|s)
where $\pi(a|s)$ is the policy.
Now, remark with $r : \mathcal{S} \times \mathcal{A} \to \mathbb{R}$ the reward function.
\mathbb{E}^\pi[\sum_{t=0}^{\infty} \gamma^t r(S_t, A_t)] = \sum_{t=0}^{\infty} \gamma^t \mathbb{E}^\pi[r(S_t, A_t)] = \sum_{t=0}^{\infty} \gamma^t \sum_{s \in \mathcal{S}} \sum_{a \in \mathcal{A}} r(s,a) \mathbb{P}^\pi(S_t = s, A_t = a)
= \sum_{s \in \mathcal{S}} \sum_{a \in \mathcal{A}} \sum_{t=0}^{\infty} \gamma^t \mathbb{P}^\pi(S_t = s) \pi(a|s) r(s,a)
= \sum_{s \in \mathcal{S}} \sum_{a \in \mathcal{A}} \mu(s) \pi(a|s) r(s,a)
= \mathbb{E}_\mu\mathbb{E}_\pi[r(S,A)]
Let's break down what happened here.
We started by averaging the reward of the trajectory $(S_0, A_0, S_1, A_1, \ldots)$ that is characterised by the distribution $\mathbb{P}^\pi$. This distribution characterised a trajectory (that's why I used the subscript $t$ inside the expectation).
On the other hand, the distribution $\mu$ is defined on the state-space $\mathcal{S}$ and characterises the probability a state is visited (that's why I do not used the subscript $t$ inside the expectation, to mark the time-independence of the random variable).
Consequently $\mathbb{P}^\pi$ and $\mu$ are two different distributions that are defined on different spaces! The distribution $\mu$ averages over the time inherently.
This kind of change of measure often appears in RL literature and are not always obvious to understand.
Introducing the discounted measure allows in practice to sample state-action pairs $(X, A) \in \mathcal{X} \times \mathcal{A}$ to evaluate the objective function, instead of doing trajectory-based Monte-Carlo methods. In practice, it is very convenient and allows to employ "replay-buffer" for instance.
Going back to your question we have observed the importance of discounting in the "continual case" (infinite trajectories).
Why multiplying by $\gamma$ introduces a termination condition?
Take a probability distribution $\mu(\cdot)$ or $\mathcal{P}(\cdot, x, a)$ for some $x \in \mathcal{S}$ and $a \in \mathcal{A}$.
Then
\int_\mathcal{S} \gamma \mu(s) ds = \gamma \int_\mathcal{S} \mu(s) ds = \gamma
= \gamma \int_\mathcal{S} \mathcal{P}(s, x, a) ds
So both distribution $\gamma \mu$ and $\gamma \mathcal{P}$ are not probability distributions anymore! They are not normalised to 1. One possible way to get a probability distribution is to normalise it OR to introduce a state $s_{\text{end}}$ that is absorbing and has a reward of 0 with a probability of $1-\gamma$. This new MDP constructed by augmenting the state space with $s_{\text{end}}$ is then considered.
For mathematicians, to work rigorously with $\mu$ it is always better to use its truncated version and pass to the limit since limits of measures are still measures when the limit exists.
[1]: A. Agarwal et al. - Reinforcement Learning: Theory and Algorithms
