I am trying to make a big classification model using the coco2017 dataset. Here is my code:
import tensorflow as tf
from tensorflow import keras
import numpy as np
import matplotlib.pyplot as plt
import IPython.display as display
from PIL import Image, ImageSequence
import os
import pathlib
from tensorflow.keras.models import Sequential
from tensorflow.keras.layers import Dense, Conv2D, Flatten, Dropout, MaxPooling2D
from tensorflow.keras.preprocessing.image import ImageDataGenerator
import cv2
import datetime
gpus = tf.config.list_physical_devices('GPU')
if gpus:
try:
# Currently, memory growth needs to be the same across GPUs
for gpu in gpus:
tf.config.experimental.set_memory_growth(gpu, True)
logical_gpus = tf.config.experimental.list_logical_devices('GPU')
print(len(gpus), "Physical GPUs,", len(logical_gpus), "Logical GPUs")
except RuntimeError as e:
# Memory growth must be set before GPUs have been initialized
print(e)
epochs = 100
steps_per_epoch = 10
batch_size = 70
IMG_HEIGHT = 200
IMG_WIDTH = 200
train_dir = "Train"
test_dir = "Val"
train_image_generator = ImageDataGenerator(rescale=1. / 255)
test_image_generator = ImageDataGenerator(rescale=1. / 255)
train_data_gen = train_image_generator.flow_from_directory(batch_size=batch_size,
directory=train_dir,
shuffle=True,
target_size=(IMG_HEIGHT, IMG_WIDTH),
class_mode='sparse')
test_data_gen = test_image_generator.flow_from_directory(batch_size=batch_size,
directory=test_dir,
shuffle=True,
model = Sequential([
Conv2D(265, 3, padding='same', activation='relu', input_shape=(IMG_HEIGHT, IMG_WIDTH ,3)),
MaxPooling2D(),
Conv2D(64, 3, padding='same', activation='relu'),
MaxPooling2D(),
Conv2D(32, 3, padding='same', activation='relu'),
MaxPooling2D(),
Flatten(),
keras.layers.Dense(256, activation="relu"),
keras.layers.Dense(128, activation="relu"),
keras.layers.Dense(80, activation="softmax")
optimizer = tf.keras.optimizers.Adam(0.001)
optimizer.learning_rate.assign(0.0001)
model.compile(optimizer='adam',
loss="sparse_categorical_crossentropy",
metrics=['accuracy'])
model.summary()
tf.keras.utils.plot_model(model, to_file="model.png", show_shapes=True, show_layer_names=True, rankdir='TB')
checkpoint_path = "training/cp.ckpt"
checkpoint_dir = os.path.dirname(checkpoint_path)
cp_callback = tf.keras.callbacks.ModelCheckpoint(filepath=checkpoint_path,
save_weights_only=True,
verbose=1)
os.system("rm -r logs")
log_dir = "logs/fit/" + datetime.datetime.now().strftime("%Y%m%d-%H%M%S")
tensorboard_callback = tf.keras.callbacks.TensorBoard(log_dir=log_dir, histogram_freq=1)
model.load_weights(tf.train.latest_checkpoint(checkpoint_dir))
history = model.fit(train_data_gen,steps_per_epoch=steps_per_epoch,epochs=epochs,validation_data=test_data_gen,validation_steps=10,callbacks=[cp_callback, tensorboard_callback])
model.save('model.h5', include_optimizer=True)
test_loss, test_acc = model.evaluate(test_data_gen)
print("Tested Acc: ", test_acc)
print("Tested Acc: ", test_acc*100, "%")
I have tried different optimizers like SGD, RMSProp, and ADAM. I also tried changing the configuration of the hidden layers. I also tried to change the metrics from accuracy to sparse_categorical_accuracy with no improvement. I cannot go beyond 30% accuracy. My guess is that the MaxPooling is doing something because I just added it but don't know what it means. Can somebody explain what the MaxPooling Layer does and what is stopping my neural network from gaining accuracy?
