Some algorithms in the literature allow recovering the input data used to train a neural network. This is done using the gradients (updates) of weights, such as in Deep Leakage from Gradients (2019) by Ligeng Zhu et al.
In case the neural network is trained using encrypted (homomorphic) input data, what could be the output of the above algorithm? Will the algorithm recover the data in clear or encrypted (as it was fed encrypted)?
nbro
  • 42,615
  • 119
  • 217
witdev
  • 73
It will recover the encrypted inputs.
The algorithm starts with dummy data and dummy labels, and then iteratively optimizes the dummy gradients to be close as to the original. This makes the dummy data close to the real training data:
$$\mathbf{x}^{\prime *}, \mathbf{y}^{\prime *}=\underset{\mathbf{x}^{\prime}, \mathbf{y}^{\prime}}{\arg \min }\left\|\nabla W^{\prime}-\nabla W\right\|^{2}=\underset{\mathbf{x}^{\prime}, \mathbf{y}^{\prime}}{\arg \min }\left\|\frac{\partial \ell\left(F\left(\mathbf{x}^{\prime}, W\right), \mathbf{y}^{\prime}\right)}{\partial W}-\nabla W\right\|^{2}$$
As the distance is minimized, the algorithm restores the original training data; in the case of encrypted training data - you should get an encrypted input (up to failures when the resulted 'input' isn't close to the original input).
rkellerm
  • 334
