I know this question may be so silly, but I can not prove it.
In Stanford slide (page 17), they define the formula of SGD with momentum like this:
$$ v_{t}=\rho v_{t-1}+\nabla f(x_{t-1}) \\ x_{t}=x_{t-1}-\alpha v_{t}, $$
where:
  • $v_{t+1}$ is the momentum value
  • $\rho$ is a friction, let say it's equal 0.9
  • $\nabla f(x_{t-1})$ is the gradient of the objective function at iteration $t-1$
  • $x_t$ are the parameters
  • $\alpha$ is the learning rate
However, in this paper and many other documents, they define the equation like this:
$$ v_{t}=\rho v_{t-1}+\alpha \nabla f(x_{t-1}) \\ x_{t}=x_{t-1}- v_{t}, $$
where $\rho$ and $\alpha$ still have the same value as in the previous formula.
I think it should be
$$v_{t}=\alpha \rho v_{t-1}+\alpha \nabla f(x_{t-1})$$
if we want to multiply the learning rate inside the equation.
In some other document (this) or normal form of momentum, they define like this:
$$ v_{t}= \rho v_{t-1}+ (1- \rho) \nabla f(x_{t-1}) \\ x_{t}=x_{t-1}-\alpha v_{t} $$
I can not understand how can they prove those equations are similar. Can someone help me?
CuCaRot
  • 932
  • 16
The first two equations are equivalent. The last equation can be equivalent if you scale $\alpha$ appropriately.
Equation 1
Consider the equation from the Stanford slide:
Let's evaluate the first few $v_t$ so that we can arrive at a closed form solution:
$v_0 = 0 \\ v_1 = \rho v_0 + \nabla f(x_0) = \nabla f(x_0)\\ v_2 = \rho v_1 + \nabla f(x_1) = \rho \nabla f(x_0) + \nabla f(x_1)\\ v_3 = \rho v_2 + \nabla f(x_2) = \rho^2 \nabla f(x_0) + \rho \nabla f(x_1) + \nabla f(x_2)\\ \dots \\ v_t = \displaystyle \sum_{i=0}^{t-1} \rho^{t-1-i} \nabla f(x_i) $
So the closed form update is:
$$x_t = x_{t-1} - \alpha \displaystyle \sum_{i=0}^{t-1} \rho^{t-1-i} \nabla f(x_i)$$
Equation 2
Now consider the equation from the paper: $$ v_{t}=\rho v_{t-1}+\alpha \nabla f(x_{t-1}) \\ x_{t}=x_{t-1}- v_{t}, $$
We again evaluate the first few $v_t$ to arrive at a closed form solution:
$v_0 = 0 \\ v_1 = \rho v_0 + \alpha \nabla f(x_0) = \alpha \nabla f(x_0)\\ v_2 = \rho v_1 + \alpha \nabla f(x_1) = \rho \alpha \nabla f(x_0) + \alpha \nabla f(x_1)\\ v_3 = \rho v_2 + \alpha \nabla f(x_2) = \rho^2 \alpha \nabla f(x_0) + \rho \alpha \nabla f(x_1) + \alpha \nabla f(x_2)\\ \dots \\ v_t = \displaystyle \sum_{i=0}^{t-1} \rho^{t-1-i} \alpha \nabla f(x_i) $
So the closed from update is:
$$x_t = x_{t-1} - \displaystyle \sum_{i=0}^{t-1} \rho^{t-1-i} \alpha \nabla f(x_i)$$
As you can see, this is equivalent to the previous closed form update. The only difference is if $\alpha$ is inside or outside the summation, but since it is a constant, it doesn't really matter anyways.
Equation 3
As for the last equation
$$ v_{t}= \rho v_{t-1}+ (1- \rho) \nabla f(x_{t-1}) \\ x_{t}=x_{t-1}-\alpha v_{t} $$ Let's do the same thing:
$v_0 = 0 \\ v_1 = \rho v_0 + (1-\rho) \nabla f(x_0) = (1-\rho) \nabla f(x_0)\\ v_2 = \rho v_1 + (1-\rho) \nabla f(x_1) = \rho (1-\rho) \nabla f(x_0) + (1-\rho) \nabla f(x_1)\\ v_3 = \rho v_2 + (1-\rho) \nabla f(x_2) = \rho^2 (1-\rho) \nabla f(x_0) + \rho (1-\rho) \nabla f(x_1) + (1-\rho) \nabla f(x_2)\\ \dots \\ v_t = \displaystyle \sum_{i=0}^{t-1} \rho^{t-1-i} (1-\rho) \nabla f(x_i) $
And so the closed form update is:
$$x_t = x_{t-1} - \alpha \displaystyle \sum_{i=0}^{t-1} \rho^{t-1-i} (1-\rho) \nabla f(x_i)$$
This equation is equivalent to the other two as long as you scale $\alpha$ by a factor of $\displaystyle \frac{1}{1-\rho}$.
user3667125
  • 1,700
  • 16
