I am reading about local search: hill climbing, and its types, and simulated annealing
One of the hill climbing versions is "stochastic hill climbing", which has the following definition:
Stochastic hill climbing does not examine for all its neighbor before moving. Rather, this search algorithm selects one neighbor node at random and decides whether to choose it as a current state or examine another state
Some sources mentioned that it can be used to avoid local optima.
Then I was reading about simulated annealing and its definition:
At every iteration, a random move is chosen. If it improves the situation then the move is accepted, otherwise it is accepted with some probability less than 1
So, what is the main difference between the two approaches? Does the stochastic choose only random (uphill) successor? If it chooses only (uphill-successors), then how does it avoid local optima?
nbro
  • 42,615
  • 119
  • 217
yaminoyuki
  • 247
Russell and Norvig's book (3rd edition) describe these two algorithms (section 4.1.1., p. 122) and this book is the reference that you should generally use when studying search algorithms in artificial intelligence. I am familiar with simulated annealing (SA), given that I implemented it in the past to solve a combinatorial problem, but I am not very familiar with stochastic hill climbing (SHC), so let me quote the parts of the book that describe SHC.
Stochastic hill climbing chooses at random from among the uphill moves; the probability of selection can vary with the steepness of the uphill move. This usually converges more slowly than steepest ascent, but in some state landscapes, it finds better solutions.
So, SHC chooses at random one "uphill move", i.e. a move that improves the objective function (for example, if you're trying to solve the travelling salesman problem, a "uphill move" could be any change to the current Hamiltonian cycle, a solution, so that the new Halmitonian cycle has a shorter cost) among the uphill moves (so among some set of moves that improve the objective).
In simulated annealing, you perform some move. If that move leads to a better solution, you always keep the better solution. If it leads to a worse solution, you accept that worse solution with a certain probability. There are other details, such as how you accept the worse solution (which you can find in Russell and Norvig's book), but this should already clarify that SA is different from SHC: SA can accept worse solutions in order to escape from local minima, while SHC accepts only uphill moves.
nbro
  • 42,615
  • 119
  • 217
