When we find the eigenvectors of a graph (say in the context of spectral clustering), what exactly is the vector space involved here? Of what vector space (or eigenspace) are we finding the eigenvalues of?
nbro
  • 42,615
  • 119
  • 217
In spectral clustering we not find the eigenvectors of a graph (a graph is not a matrix) but the eigenvalues/eigenvectors of the Laplacian matrix related to the adjacency matrix of the graph:
graph => adjacency matrix => Laplacian matrix => eigenvalues (spectrum).
The adjacency matrix describes the "similarity" between two graph vertexs. In the most simple case (undirected unweighted simple graph), a value "1" in the matrix means two vertex joined by an edge, a value "0" means no edge between these vertex.
So, the space under the adjacency matrix is the space of connectivity, being row "i" of a column vector a measure of the connectivity with vertex "i". In other words, the adjacency and Laplacian matrix map from vertexs to vertex connectivity.
Example
Assume a simple graph with 3 vertex {1,2,3} and edges (1,2) and (2,3). The respective Laplacian matrix is:
$$ A=\begin{pmatrix} 1 & -1 & 0\\ -1 & 2 & -1\\ 0 & -1 & 1 \end{pmatrix} $$
a) vertex 1, than in vertex space is (1,0,0) maps to:
$$ A\begin{pmatrix} 1\\ 0\\ 0 \end{pmatrix} = \begin{pmatrix} 1\\ -1\\ 0 \end{pmatrix} $$
if we analyze the product result, component by component, it means:
  • vertex 1 is connected to 1 node.
  • vertex 2 is connected to vertex 1
  • vertex 3 is not connected to vertex 1.
b) the set of vertexs 1 and 2, that is represented in vertex space as (1,1,0), maps to:
$$ A\begin{pmatrix} 1\\ 1\\ 0 \end{pmatrix} = \begin{pmatrix} 0\\ 1\\ -1 \end{pmatrix} $$
meaning that:
  • vertex 1 is internal or external to the set {1,2}, not frontier (in this concrete case, it is internal: belongs to set and has no edge with any node out of the set).
  • vertex 2 is a vertex in the set and connected to one vertex out of the set (internal frontier).
  • vertex 3 is a vertex not in the set but connected to it (external frontier).
Finally, see what happens if multiply (inner/scalar product) previous result by the vertex vector again:
$$ \begin{pmatrix} 1 & 1 & 0 \end{pmatrix} A\begin{pmatrix} 1\\ 1\\ 0 \end{pmatrix} = 1 $$
it gives the number of edges that connects the set of nodes {1,2} with the remainder graph.
pasaba por aqui
  • 1,313
