10
Based on fitting to historical data and extrapolation, when is it expected that the number of neurons in AI systems will equal those of the human brain?
I'm interested in a possible direct replication of the human brain, which will need equal numbers of neurons.
Of course, this assumes neurons which are equally capable as their biological counterparts, which development may happen at a faster or slower rate than the quantitative increase.
Tom Hale
  • 384
  • 13
6 Answers6
17
Some back of the envelope calculations :
The number of neurons in AI systems is a little tricky to calculate, Neural Networks and Deep Learning are 2 current AI systems as you call them, specifics are hard to come by (If someone has them please share), but data on parameters do exist, parameters are more analogous to synapses (connections) than neurons (the nodes in between connections) somewhere in the range of 100-160 billion is the current upper number for specialized networks.
Deriving the number of neurons in AI systems from this number is a stretch since these AIs emulate certain types of connections and sub assemblies of neurons, but let's continue...
So now let's look at the brain, and again this are all contested numbers. Number of neurons ~ 86 Billion, Number of Synapses ~ 150 Trillion, another generalization: average number of synapses per neuron ~ 1,744.
So now we have something to compare, and I can't stress this enough, these are all wonky numbers, so let's make our life a little easier and divide :
Number of Synapses (Brain ) : 150 trillion / Number of parameters AIs : 150 billion = 1,000 or in other words current AIs would have to scale by a factor of one thousand their connections to be on par with the brain...
Number of Neurons (Brain ) : 86 Billion / Number of Neurons AIs ( 150 billion / 1,744 ) = 86 Million equivalent AI Neurons
Which makes sense, mathematically at least : you can multiply the factor ( 1000 ) times the current number of equivalent AI Neurons ( 86 million) to get the number of neurons in the human brain (86 Billion)
When ?
Well,let's use moore's law ( number of transistors processing power doubles about every 2 years ) as a rough measure of technological progress:
     #AI NEURONS            YEAR
     86,000,000             2016
     172,000,000            2018
     344,000,000            2020
     688,000,000            2022
     1,376,000,000          2024
     2,752,000,000          2026
     5,504,000,000          2028
     11,008,000,000         2030
     22,016,000,000         2032
     44,032,000,000         2034
     88,064,000,000         2036
     # NEURONS HUMAN BRAIN
     86,000,000,000
So, if all this made sense to you, somewhere around the year 2035.
Keno
  • 545
  • 14
Soon enough but that doesn't mean anything at all. In machine learning the word neuron represents a calculation whereas in brain the word neuron represent a specific type of cell which is a biochemical system.
Ankur
  • 531
The answers so far haven't answered the question numerically, so here is my attempt to steer them in the direction I was seeking:
The freely available Deep Learning Book has the following figure on page 27:
Size of neural nets over time
I question the blue fit line, as it seems that data points may be better described by a parabolic or exponential function.
In any case, based upon this conservative linear fit, the authors predict that the number of neurons in a ANN will equal that of the human brain in 2056.
The referenced nerual networks are:
Neural networks referred to in image above
What is interesting to note that when The Singularity is Near was written in 2006, Ray Kurzweil said that the refractory period of a biological neuron was already 1,000,000 times slower than that of an artificial one.
Tom Hale
  • 384
  • 13
While interesting, this is all rendered somewhat moot if you think about what will happen once we understand how the brain works. After all, once we understood flight, we didn't start making birds. The same goes for AI. Here are just a few ways in which human brains and digital brains can't be compared.
The digital brain won't have to worry about food and drink. They will also be more reliable (or less redundant) as electronics is way more reliable than neurons (a guess). Digital brains will also be able to share learning and information. Once one Model 3X digital brain has learned something, the others need merely to have the bits uploaded. Sure, it will be more complicated than that but, remember, we will know how it all works so merging the experiences of one digital being with another should be doable. If we want our digital brain to have symbolic algebra ability, we will have to teach it some things but we can also hard-wire it to Mathematica or the like.
In short, it will be like apples and oranges.
Paul Topping
  • 131
The human brain contains billions of neurons, which means we won't be making one tomorrow. However, technology tends to advance in an exponential manner, and that may soon be a real possibility. Also, the idea of making an artificial human brain would not only take more neurons than a current average computer could process, or we could make outside of computers, but we also need an understanding of the human brain. There is only one animal with neurons that we have completed a full connectome of and that is the Caenorhabditis elegans (roundworm) and it has less than 500 neurons. It may be a while before we actually make a human brain, but within 30 years is a reasonable estimation with the rate that technology improves now.
I. Golsby
  • 111
2035, 2056? Those predictions are hilarious :)
2019 - 1,6Billion parameter model (GPT-2)
2020 -175Billion parameter model (GPT-3) more than 100x jump in a year
2021(April) - "Microsoft's ZeRO-Infinity can now run a model with over a trillion parameters on a single NVIDIA DGX-2 node and over 30 trillion parameters on 32 nodes (512 GPUs). With a hundred DGX-2 nodes in a cluster, Microsoft projects ZeRO-Infinity can train models with over a hundred trillion parameters"
https://www.microsoft.com/en-us/research/blog/zero-infinity-and-deepspeed-unlocking-unprecedented-model-scale-for-deep-learning-training/
So in 2021 we now have tech to train 30Trillion- 100 Trillion parameters/neurons Model
100 trillion = Human Brain
With this tech, OpenAI together with Microsoft, other company or gov will train 100Trillion model in 2021 or 2022 at the latest
