I wish to train two domain-specific models:
  • Domain 1: Constitution and related Legal Documents
  • Domain 2: Technical and related documents.
For Domain 1, I've access to a text-corpus with texts from the constitution and no question-context-answer tuples. For Domain 2, I've access to Question-Answer pairs.
Is it possible to fine-tune a light-weight BERT model for Question-Answering using just the data mentioned above?
If yes, what are the resources to achieve this task?
Some examples, from the huggingface/models library would be mrm8488/bert-tiny-5-finetuned-squadv2, sshleifer/tiny-distilbert-base-cased-distilled-squad, /twmkn9/albert-base-v2-squad2.
nbro
  • 42,615
  • 119
  • 217
Anirban Saha
  • 141
The answer is yes but 'lightweight' will require a 'lightweight' model.
Your application for 'domain one' is called open domain question answering (ODQA). Here is a demonstration of ODQA using BERT: https://www.pragnakalp.com/demos/BERT-NLP-QnA-Demo/
Your application for 'domain two' is a little different. It is about learning sequences from sequences. More specifically these are called sequence to sequence models. Here is an example using a pre-trained BERT model fine-tuned on the Stanford Question Answering (SQuAD) dataset.
Stanford Question Answering Dataset (SQuAD) is a reading comprehension dataset, consisting of questions posed by crowdworkers on a set of Wikipedia articles, where the answer to every question is a segment of text, or span, from the corresponding reading passage, or the question might be unanswerable.
In both applications, the resources required are going to rely on the performance you require. There are many sizes of BERT models. Generally, the larger the model, the larger the GPU memory requirements, and the higher the performance (i.e. accuracy, precision, recall, F1-score, etc.). For example, I can run BERT Base on a particular data set on a GTX 1080Ti and a RTX 2080Ti but not BERT Large.
This article, NVIDIA Quadro RTX 6000 BERT Large Fine-tune Benchmarks with SQuAD Dataset shows performance for BERT using TensorFlow on four NVIDIA Quadro RTX 6000 GPUs.
There is a 'mobile' version of BERT called MobileBERT for running on small devices like smartphones. Here is an article on using that with SQuAD: https://www.tensorflow.org/lite/models/bert_qa/overview
cdQA-suite is a good package. The following should help in fine-tuning on your own corpus:
Brian O'Donnell
  • 1,997
  • 23
