Let's say we have a captcha system that consists of a greyscale picture (of a part of a street or something akin to re-captcha), divided into 9 blocks, with 2 missing pieces.
You need to choose the appropriate missing pieces from over 15 possibilities to complete the picture.
The puzzle pieces have their edges processed with glitch treatment as well as they have additional morphs such as heavy jpeg compression, random affine transform, and blurred edges.
Every challenge picture is unique - pulled from a dataset of over 3 million images.
Is it possible for the neural network to reliably (above 50%) predict the missing pieces? Sometimes these are taken out of context and require human logic to estimate the correct piece.
The chance of selecting two answers in correct order is 1/15*1/14.
Mithical
  • 2,965
  • 28
  • 39
Well to give you a short answer, I would say that YES, it would be MORE resistant than a more standard captcha approach...
This being said, I would still go as far as to predict something like a 75-80% successful prediction rates, for a custom model which is designed specifically for defeating a mechanism such as what you describe. The reason why I am fairly confident in such an appraisal, is primarily because of the following:
  1. New techniques which researchers have begun to explore, which are intended to be "Structure Preserving Convolutions" which utilize a higher dimensional filter to store the extra correlation data.
  2. I think that the obfuscation efforts that you mention will definitely help to some degree, although they can be easily defeated by training the model on a dataset which you pull out some portion of the samples during pre-processing and inject the same sort of noise and glitch treatments, etc.
    • An idea that would be worth exploring would be to process your dataset with an adversarial model which you could then use to generate Adversarial Noise that could then be fed into a pre-process step for your images and replace (or extend) the obfuscation efforts!
TL;DR: If you cant beat 'em, then join 'em! Just train a model to defeat your captcha implementation, and then use the model to generate adversarial examples and then apply obfuscations to your data set accordingly!
For more information on what I am talking about in my suggestion for further obfuscation efforts explore some of the papers you can find on Google Scholar - Ensemble Adversarial Training Examples
This is not resistant at all. A simple comparison on the similarity of edge pixels between borders should be very sufficient to break this method completely.
We can do a very simple calculation. Assume the picture is 8bit black and white with each border being 50x50 pixels. Also assume the distribution is continuously uniform between 0-255 (should probably be normally distributed, but whatever). You have a total of 200 pixels that border each other in between borders. Assume that the naturally generated image is continuous in brightness with respect to dimension in at least 10% of the image with +/- 10 units of brightness is acceptable. Thus we have 20 pixels to work with.
In the case where the image is incorrect, we assume the pixel brightness to be iid in [0-255], thus giving us roughly a 8% (21/256) chance of each pixel around the border to be of acceptable similarity. Which gives us about a 10^-22 chance of this algorithm being fooled. You might disagree with my assumed parameters, but to be frank I am probably being too generous in estimating a lower bound.
There are two lessons here: 1. Just because you and others can't think of a way to break your secure system doesn't mean it's actually secure. 2. Modern ML techniques are not strictly stronger than handcrafted algorithms, though I would also imagine that a simple NN would be able to solve this problem easily.
k.c. sayz 'k.c sayz'
  • 2,121
  • 13
  • 27
