Imagine that we have a set of heuristic functions $\{h_i\}_{i=1}^N$, where each $h_i$ is both admissible and consistent (monotonic). Is $\sum_{i=1}^N h_i$ still consistent or not?
Is there any proof or counterexample to show the contradiction?
nbro
  • 42,615
  • 119
  • 217
No, it will not necessary be consistent or admissible. Consider this example, where $s$ is the start, $g$ is the goal, and the distance between them is 1.
s --1-- g
Assume that $h_0$ and $h_1$ are perfect heuristics. Then $h_0(s) = 1$ and $h_1(s) = 1$. In this case the heuristic is inadmissible because $h_0(s)+h_1(s) = 2 > d(s, g)$. Similarly, as an undirected graph the heuristic will be inconsistent because $|h(s)-h(g)| > d(s, g)$.
If you'd like to understand the conditions for the sum of heuristics to be consistent and admissible, I would look at the work on additive PDB heuristics.
Nathan S.
  • 371
