I'm testing out YOLOv3 using the 'darknet' binary, and custom config. It trains rather slow.
My testing out is only with 1 image, 1 class, and using YOLOv3-tiny instead of YOLOv3 full, but the training of yolov3-tiny isn't fast as expected for 1 class/1 image.
The accuracy reached near 100% after like 3000 or 4000 batches, in similarly 3 to 4 hours.
Why is it slow with just 1 class/1 image?
Dan D
  • 1,318
  • 14
  • 39
I think you underestimate the size of YOLO. This is the size of one segment of yolo tiny according to the darknet .cfg file:
Convolutional Neural Network structure:
416x416x3                Input image
416x416x16               Convolutional layer: 3x3x16, stride = 1, padding = 1
208x208x16               Max pooling layer: 2x2, stride = 2
208x208x32               Convolutional layer: 3x3x32, stride = 1, padding = 1
104x104x32               Max pooling layer: 2x2, stride = 2
104x104x64               Convolutional layer: 3x3x64, stride = 1, padding = 1
52x52x64                 Max pooling layer: 2x2, stride = 2
52x52x128                Convolutional layer: 3x3x128, stride = 1, padding = 1
26x26x128                Max pooling layer: 2x2, stride = 2
26x26x256                Convolutional layer: 3x3x256, stride = 1, padding = 1
13x13x256                Max pooling layer: 2x2, stride = 2
13x13x512                Convolutional layer: 3x3x512, stride = 1, padding = 1
12x12x512                Max pooling layer: 2x2, stride = 1
12x12x1024               Convolutional layer: 3x3x1024, stride = 1, padding = 1
.cfg file found here: https://github.com/pjreddie/darknet/blob/master/cfg/yolov3-tiny.cfg
EDIT: These networks generally aren't specifically designed to train fast, they're designed to run fast at test time, where it matters
Recessive
  • 1,446
It depends upon the factors such as 1. Batch size (GPU memory capacity) 2. CPU speed and number of cores(multi-threading to load the images)
Number of classes increase the number of convolution filters only in the prediction layers of YOLO. It influences only less than 1% speed of the detector to train the model.
Sudhakar17
  • 31
