12
To give an example. Let's just consider the MNIST dataset of handwritten digits. Here are some things which might have an impact on the optimum model capacity:
  • There are 10 output classes
  • The inputs are 28x28 grayscale pixels (I think this indirectly affects the model capacity. eg: if the inputs were 5x5 pixels, there wouldn't be much room for varying the way an 8 looks)
So, is there any way of knowing what the model capacity ought to be? Even if it's not exact? Even if it's a qualitative understanding of the type "if X goes up, then Y goes down"?
Just to accentuate what I mean when I say "not exact": I can already tell that a 100 variable model won't solve MNIST, so at least I have a lower bound. I'm also pretty sure that a 1,000,000,000 variable model is way more than needed. Of course, knowing a smaller range than that would be much more useful!
nbro
  • 42,615
  • 119
  • 217
Alexander Soare
  • 1,379
  • 28
Theoretical results
Rather than providing a rule of thumb (which can be misleading, so I am not a big fan of them), I will provide some theoretical results (the first one is also reported in paper How many hidden layers and nodes?), from which you may be able to derive your rules of thumb, depending on your problem, etc.
Result 1
The paper Learning capability and storage capacity of two-hidden-layer feedforward networks proves that a 2-hidden layer feedforward network ($F$) with $$2 \sqrt{(m + 2)N} \ll N$$ hidden neurons can learn any $N$ distinct samples $D= \{ (x_i, t_i) \}_{i=1}^N$ with an arbitrarily small error, where $m$ is the required number of output neurons. Conversely, a $F$ with $Q$ hidden neurons can store at least $\frac{Q^2}{4(m+2)}$ any distinct data $(x_i, t_i)$ with any desired precision.
They suggest that a sufficient number of neurons in the first layer should be $\sqrt{(m + 2)N} + 2\sqrt{\frac{N}{m + 2}}$ and in the second layer should be $m\sqrt{\frac{N}{m + 2}}$. So, for example, if your dataset has size $N=10$ and you have $m=2$ output neurons, then you should have the first hidden layer with roughly 10 neurons and the second layer with roughly 4 neurons. (I haven't actually tried this!)
However, these bounds are suited for fitting the training data (i.e. for overfitting), which isn't usually the goal, i.e. you want the network to generalize to unseen data.
This result is strictly related to the universal approximation theorems, i.e. a network with a single hidden layer can, in theory, approximate any continuous function.
Model selection, complexity control, and regularisation
There are also the concepts of model selection and complexity control, and there are multiple related techniques that take into account the complexity of the model. The paper Model complexity control and statistical learning theory (2002) may be useful. It is also important to note regularisation techniques can be thought of as controlling the complexity of the model [1].
Further reading
You may also want to take a look at these related questions
(I will be updating this answer, as I find more theoretical results or other useful info)
nbro
  • 42,615
  • 119
  • 217
This may sound counter intuitive but one of the biggest rules of thumb for model capacity in deep learning:
IT SHOULD OVERFIT.
Once you get a model to overfit, its easier to experiment with regularizations, module replacements, etc. But in general, it gives you a good starting ground.
mshlis
  • 2,399
  • 23
Personally, when I begin designing a machine learning model, I consider the following points:
  • My data: if I have simple images, like MNIST ones, or in general images with very low resolution, a very deep network is not required.
  • If my problem statement needs to learn a lot of features from each image, such as for the human face, I may need to learn eyes, nose, lips, expressions through their combinations, then I need a deep network with convolutional layers.
  • If I have time-series data, LSTM or GRU makes sense, but, I also consider recurrent setup when my data has high resolution, low count data points.
The upper limit however may get decided by resources available on the computing device you are using for training.
Hope this helps.
nbro
  • 42,615
  • 119
  • 217
anurag
  • 151
