Does the learning rate parameter $\alpha$ require the Robbins-Monro conditions below for the TD(0) algorithm to converge to the true value function of a policy?
$$\sum \alpha_t =\infty \quad \text{and}\quad \sum \alpha^{2}_t <\infty$$
nbro
  • 42,615
  • 119
  • 217
KaneM
  • 307
  • 13
The paper Convergence of Q-learning: A Simple Proof (by Francisco S. Melo) shows (theorem 1) that Q-learning, a TD(0) algorithm, converges with probability 1 to the optimal Q-function as long as the Robbins-Monro conditions, for all combinations of states and actions, are satisfied. In other words, the Robbins-Monro conditions are sufficient for Q-learning to converge to the optimal Q-function in the case of a finite MDP. The proof of theorem 1 uses another theorem from stochastic approximation (theorem 2).
You are interested in the prediction problem, that is, the problem of predicting the expected return (i.e. a value function) from a fixed policy. However, Q-learning is also a control algorithm, given that it can find the optimal policy from the corresponding learned Q-function.
See also the question Why doesn't Q-learning converge when using function approximation?.
nbro
  • 42,615
  • 119
  • 217
