Let's assume we are in a $3 \times 3$ grid world with states numbered as $0,1, \dots, 8$. Suppose that the goal state is $8$, the reward of landing in the goal state is $10$, and the reward of just wandering around in the grid world is $0$. Is the state-value of state $8$ always $0$?
In reinforcement learning, is the value of terminal/goal state always zero?
Yes, always for episodic problems, the value of a terminal state is always zero, from the definition.
The value of a state $v(s)$ is the expected sum (perhaps discounted) of rewards from all future time steps. There are no future time steps when in a terminal state, so this sum must be zero.
For the sake of consistent maths notation, you can consider a terminal state to be "absorbing", i.e. any transition out of it results in zero reward and returning to the same terminal state. Then you can use the definition of value function to show the same thing:
$$v_{\pi}(s) = \mathbb{E}_{\pi}[\sum_{k=0}^{\infty} \gamma^k R_{t+k+1} | S_{t} = s]$$
If $s = s_T$, the terminal state, then all the "future rewards" from $k=0$ onwards starting with reward $R_{t+1}$ must be zero. This is consistent with the reward $R_{t}$, i.e. the reward when transitioning to the terminal state, being any value.
You can show similar using action value functions, if you accept a "null" action in the terminal state.
- 42,615
- 12
- 119
- 217
- 33,739
- 3
- 47
- 66
