I would much appreciate if you could point me in the right direction regarding this question about targets for SARSA and Q-learning (notation: $S$ is the current state, $A$ is the current action, $R$ is the reward, $S'$ is the next state and $A'$ is the action chosen from that next state).
Do we need an explicit policy for the Q-learning target to sample $A'$ from? And for SARSA?
I guess this is true for Q-learning since we need to get max Q-value which determines which action $A'$ we'll use for the update. For SARSA, we update the $Q(S, A)$ depending on which action was actually taken (no need for max). Please correct me if I'm wrong.
nbro
  • 42,615
  • 119
  • 217
Novak
  • 123
Q-learning uses an exploratory policy, derived from the current estimate of the $Q$ function, such as the $\epsilon$-greedy policy, to select the action $a$ from the current state $s$. After having taken this action $a$ from $s$, the reward $r$ and the next state $s'$ are observed. At this point, to update the estimate of the $Q$ function, you use a target that assumes that the greedy action is taken from the next state $s'$. The greedy action is selected by the $\operatorname{max}$ operator, which can thus be thought of as an implicit policy (but this terminology isn't common, AFAIK), so, in this context, the greedy action is the action associated with the highest $Q$ value for the state $s'$.
In SARSA, no $\operatorname{max}$ operator is used, and you derive a policy (e.g. the $\epsilon$-greedy policy) from the current estimate of the $Q$ function to select both $a$ (from $s$) and $a'$ (from $s'$).
To conclude, in all cases, the policies are implicit, in the sense that they are derived from the estimate of the $Q$ function, but this isn't a common terminology. See also this answer, where I describe more in detail the differences between Q-learning and SARSA, and I also show the pseudocode of both algorithms, which you should read (multiple times) in order to fully understand their differences.
nbro
  • 42,615
  • 119
  • 217
