The selection of experimental data includes a set of vectors of different dimensions. The input is a 3-dimensional vector, and the output is a 12-dimensional vector. The sample size is 120 pairs of input 3-dimensional and output 12-dimensional vectors.
Is it possible to train such a neural network (in MATLAB)? Which structure of the neural network is best suited for this?
nbro
  • 42,615
  • 119
  • 217
ayr
  • 239
There is nothing stopping you, you can setup Dense Neural Networks to have any size inputs or outputs (simple proof is to imagine a single layer NN with no activation is just a linear transform and given input dim $n$ and output dim $m$, it's just a matrix of $n$ x $m$, trivially this works though with any number of hidden layers)
The better question is should you?. In all honesty, it depends on the data that you have, but, usually, with only 120 examples you'll either overfit completely or do relatively well if the true solution is a very simple function, but, in general, in the common situations where that isn't the case I find myself more likely or not using Bayesian approaches, so I can actually consider confidence (with little data, this is really nice)
nbro
  • 42,615
  • 119
  • 217
mshlis
  • 2,399
  • 23
The perceptron convergence theorem states that any architecture will lead to a correlation between the data.
Yes, you can!
