Currently, I'm using a Python library, StellarGraph, to implement GCN. And I now have a situation where I have graphs with weighted edges. Unfortunately, StellarGraph doesn't support those graphs
I'm looking for an open-source implementation for graph convolution networks for weighted graphs. I've searched a lot, but mostly they assumed unweighted graphs. Is there an open-source implementation for GCNs for weighted graphs?
nbro
  • 42,615
  • 119
  • 217
port trum
  • 85
You can use Pytorch_Geometric library for your projects. Its supports weighted GCNs. It is a rapidly evolving open-source library with easy to use syntax. It is mentioned in the landing page of Pytorch. It is the most starred Pytorch github repo for geometric deep learning. Creating a GCN model which can process graphs with weights is as simple as:
import torch
import torch.nn.functional as F
from torch_geometric.nn import GCNConv
class Net(torch.nn.Module):
    def __init__(self):
        super(Net, self).__init__()
        self.conv1 = GCNConv(dataset.num_node_features, 16)
        self.conv2 = GCNConv(16, dataset.num_classes)
    def forward(self, data):
        # data has the following 3 attributes
        x, edge_index, edge_weight = data.x, data.edge_index, data.edge_weight
        x = self.conv1(x, edge_index, edge_weight)
        x = F.relu(x)
        x = F.dropout(x, training=self.training)
        x = self.conv2(x, edge_index, edge_weight)
        return F.log_softmax(x, dim=1)
See this for getting started. Check out its documentation on different variants of GCNs for further details. One of the best thing is that like Pytorch, its documentation are self-sufficient.
user1825567
  • 310
A Comprehensive Survey on Graph Neural Networks (2019) presents a list of ConvGNN's. All of the following accept weighted graphs, and three accept those with edge weights as well:
And below is a series of open source implementations of many of the above:
You can use Graph Attention Networks for weighted graphs. This model can handle negative weights. Check out its documentation.
