Consider the following diagram of a graph representing a search space.
If we start at $B$ and try to reach goal state $E$, the lowest-cost first search (LCFS) (aka uniform-cost search) algorithm fails to find a solution. This is because, $B$ selects $A$ over $C$ to expand as $f(A)=g(A)=36 < f(C)=g(C)=70$. $f(n)$ is the cost function of node $n$, and $g(n)$ is the cost of reaching node $n$ from the start state. Continuing further, from $A$, LCFS will now select $B$ to expand, which in turn will select $A$ again over $C$. This leads to an infinite loop. This shows LCFS is incomplete (not guaranteed to find a solution, if one exists).
For A*, we define $f(n)=g(n)+h(n)$, where $h(n)$ is the expected cost of reaching goal state from node $n$. If we define Manhattan distance ($L_0$ norm) for $h(\cdot)$, books (such as Artificial Intelligence: A Modern Approach (3rd Ed) by Stuart Russell and Peter Norvig) says A* is bound to find the solution (since it exists). However, I couldn't find how. Using, A*, $B$ will still select $A$ since $f(A)=36+(h(A)=40)=76 < f(C)=70+(h(C)=30+50)=150$. You see, this means, when $A$ expands back $B$, $B$ will again select $A$, and an infinite loop ensues.
What am I missing here?
