In my implementation of Thompson Sampling (TS) for online Reinforcement Learning, my distribution for selecting $a$ is $\mathcal{N}(Q(s, a), \frac{1}{C(s,a)+1})$, where $C(s,a)$ is the number of times $a$ has been picked in $s$.
However, I found that this does not work well in some cases depending on the magnitude of $Q(s,a)$. For example, if $Q(s_i,a_1) = 100$, and $C(s_i,a_1) = 1$, then then this gives a standard deviation of 0.5, which is extremely confident even though the action has only been picked once. Compare that to $a_2$ which may be the optimal action but has never been picked, so $Q(s_i, a_2) = 0$ and $C(s_i,a_2) = 0$. It is unlikely that TS will ever pick $a_2$.
So, how do I solve this problem?
I tried normalizing the Q-values such that they range from 0 to 1, but the algorithm returns much lower total returns. I think I have to adapt the magnitude of the standard deviations relative to the Q-values as well. Doing it for 1 normal distribution is pretty straightforward, but I can't figure out how to do it for multiple distributions which have to take into consideration of the other distributions.
Edit: Counts should be $C(s,a)$ instead of $C(s)$ as Neil pointed out
nbro
  • 42,615
  • 119
  • 217
Kevin
  • 81
