I am pretty new to Artificial Intelligence programming, however i do understand the basic concept. I have an idea in my mind:
Import a JPEG Image, Convert this Image into a 2D Array (x,y values + r g b values). Then create a second array with same (xy) values wit rgb all set to 0,0,0. Now i want to build an AI Layer which will try to lower the error factor between the arrays until they are equal (the rgb values in the second array are equal to the first array (error factor 0) ). I would prefer to do it in Java. Any suggestions to librarys or example that can help me get started? Thanks for any help.
videokate
  • 31
For recreating an image exactly the same as the original, you can use an autoencoder. This basically use AI Layers to encode the image raw pixel values to a vector of floats, drastically decreasing the representing vector. Afterwards another AI Layer increases the dimensions back to the original image. The method does not required labels, as it only refer to teh image to encode it to a vector of features. For implementing in java, there is not a lot 9f resources. However, you can check this library out: https://deeplearning4j.org/ For the implementation, see this: https://github.com/eclipse/deeplearning4j-examples/blob/master/dl4j-examples/src/main/java/org/deeplearning4j/examples/unsupervised/variational/VariationalAutoEncoderExample.java For the method, you can see this python tutorial and implement it in java. https://towardsdatascience.com/autoencoders-in-keras-c1f57b9a2fd7
For generating completely new image, you can try GAN(Generative Adverserial Network). This generates completely new images from a random noise image. The noise image is passed through a generator which is a CNN(convolutional neural network) and get a result image. The result image is then feed to a discriminator(CNN as well) to classify if that image is fake or real. The generator and discriminator compete and slowly gets better. For java implementation, see this: https://github.com/wmeddie/dl4j-gans
Hope I can help you and have a nice day!
Clement
  • 1,755
  • 24
