The Transformer model introduced in "Attention is all you need" by Vaswani et al. incorporates a so-called position-wise feed-forward network (FFN):
In addition to attention sub-layers, each of the layers in our encoder and decoder contains a fully connected feed-forward network, which is applied to each position separately and identically. This consists of two linear transformations with a ReLU activation in between.
$$\text{FFN}(x) = \max(0, x \times {W}_{1} + {b}_{1}) \times {W}_{2} + {b}_{2}$$
While the linear transformations are the same across different positions, they use different parameters from layer to layer. Another way of describing this is as two convolutions with kernel size 1. The dimensionality of input and output is ${d}_{\text{model}} = 512$, and the inner-layer has dimensionality ${d}_{ff} = 2048$.
I have seen at least one implementation in Keras that directly follows the convolution analogy. Here is an excerpt from attention-is-all-you-need-keras.
class PositionwiseFeedForward():
def __init__(self, d_hid, d_inner_hid, dropout=0.1):
self.w_1 = Conv1D(d_inner_hid, 1, activation='relu')
self.w_2 = Conv1D(d_hid, 1)
self.layer_norm = LayerNormalization()
self.dropout = Dropout(dropout)
def __call__(self, x):
output = self.w_1(x)
output = self.w_2(output)
output = self.dropout(output)
output = Add()([output, x])
return self.layer_norm(output)
Yet, in Keras you can apply a single Dense layer across all time-steps using the TimeDistributed wrapper (moreover, a simple Dense layer applied to a 2D input implicitly behaves like a TimeDistributed layer). Therefore, in Keras a stack of two Dense layers (one with a ReLU and the other one without an activation) is exactly the same thing as the aforementioned position-wise FFN. So, why would you implement it using convolutions?
Update
Adding benchmarks in response to the answer by @mshlis:
import os
import typing as t
os.environ['CUDA_VISIBLE_DEVICES'] = '0'
import numpy as np
from keras import layers, models
from keras import backend as K
from tensorflow import Tensor
# Generate random data
n = 128000 # n samples
seq_l = 32 # sequence length
emb_dim = 512 # embedding size
x = np.random.normal(0, 1, size=(n, seq_l, emb_dim)).astype(np.float32)
y = np.random.binomial(1, 0.5, size=n).astype(np.int32)
# Define constructors
def ffn_dense(hid_dim: int, input_: Tensor) -> Tensor:
output_dim = K.int_shape(input_)[-1]
hidden = layers.Dense(hid_dim, activation='relu')(input_)
return layers.Dense(output_dim, activation=None)(hidden)
def ffn_cnn(hid_dim: int, input_: Tensor) -> Tensor:
hidden = layers.Conv1D(hid_dim, 1, activation='relu')(input_)
return layers.Conv1D(output_dim, 1, activation=None)(hidden)
def build_model(ffn_implementation: t.Callable[[int, Tensor], Tensor],
ffn_hid_dim: int,
input_shape: t.Tuple[int, int]) -> models.Model:
input_ = layers.Input(shape=(seq_l, emb_dim))
ffn = ffn_implementation(ffn_hid_dim, input_)
flattened = layers.Flatten()(ffn)
output = layers.Dense(1, activation='sigmoid')(flattened)
model = models.Model(inputs=input_, outputs=output)
model.compile(optimizer='Adam', loss='binary_crossentropy')
return model
# Build the models
ffn_hid_dim = emb_dim * 4 # this rule is taken from the original paper
bath_size = 512 # the batchsize was selected to maximise GPU load, i.e. reduce PCI IO overhead
model_dense = build_model(ffn_dense, ffn_hid_dim, (seq_l, emb_dim))
model_cnn = build_model(ffn_cnn, ffn_hid_dim, (seq_l, emb_dim))
# Pre-heat the GPU and let TF apply memory stream optimisations
model_dense.fit(x=x, y=y[:, None], batch_size=bath_size, epochs=1)
%timeit model_dense.fit(x=x, y=y[:, None], batch_size=bath_size, epochs=1)
model_cnn.fit(x=x, y=y[:, None], batch_size=bath_size, epochs=1)
%timeit model_cnn.fit(x=x, y=y[:, None], batch_size=bath_size, epochs=1)
I am getting 14.8 seconds per epoch with the Dense implementation:
Epoch 1/1
128000/128000 [==============================] - 15s 116us/step - loss: 0.6332
Epoch 1/1
128000/128000 [==============================] - 15s 115us/step - loss: 0.5327
Epoch 1/1
128000/128000 [==============================] - 15s 117us/step - loss: 0.3828
Epoch 1/1
128000/128000 [==============================] - 14s 113us/step - loss: 0.2543
Epoch 1/1
128000/128000 [==============================] - 15s 116us/step - loss: 0.1908
Epoch 1/1
128000/128000 [==============================] - 15s 116us/step - loss: 0.1533
Epoch 1/1
128000/128000 [==============================] - 15s 117us/step - loss: 0.1475
Epoch 1/1
128000/128000 [==============================] - 15s 117us/step - loss: 0.1406
14.8 s ± 170 ms per loop (mean ± std. dev. of 7 runs, 1 loop each)
and 18.2 seconds for the CNN implementation. I am running this test on a standard Nvidia RTX 2080. So, from a performance perspective there seems to be no point in actually implementing an FFN block as a CNN in Keras. Considering that the maths are the same, the choice boils down to pure aesthetics.
