It (Adagrad) adapts the learning rate to the parameters, performing smaller updates (i.e. low learning rates) for parameters associated with frequently occurring features, and larger updates (i.e. high learning rates) for parameters associated with infrequent features.
From Sebastian Ruder's Blog
If a parameter is associated with an infrequent feature then yes, it is more important to focus on properly adjusting that parameter since it is more decisive in classification problems. But how does making the learning rate higher in this situation help?
If it only changes the size of the movement in the dimension of the parameter (makes it larger) wouldn't that make things even more imprecise? Since the network depends more on those infrequent features, shouldn't adjusting those parameters be done more precisely instead of just faster? The more decisive parameters should have a higher "slope", thus why should they also have high learning rates? I must be missing something, but what is it?
Further, in the article, the formula for parameter adjustments with Adagrad is given. Where exactly in that formula do you find the information about the frequency of a parameter? There must be a relationship between the gradients of a parameter and the frequency of features associated with it because it's the gradients that play an important role in the formula. What is that relationship?
TLDR: I don't understand both the purpose and formula behind Adagrad. What is an intuitive explanation of it that also provides an answer to the questions above, or shows why they are irrelevant?
malioboro
  • 2,859
  • 23
  • 47
DaddyMike
  • 123
I found a somewhat more accessible introduction here:
https://medium.com/konvergen/an-introduction-to-adagrad-f130ae871827
Let me start from the last part of your question. The frequency of a parameter is in G_t, which is the accumulated sum of squared gradients from all the time steps up to step t. If the gradient vanishes in many of the previous steps, then you divide the learning rate with a smaller number for that parameter.
And for the first part, you want the parameter that is more frequent to have a smaller learning rate as it is updated on more iterations compared to a parameter which is updated only a small number of times.
serali
  • 900
  • 17
