I have implemented a CNN for image classification. I have not used fully connected layers, but only a softmax. Still, I am getting results.
Must I use fully-connected layers in a CNN?
nbro
  • 42,615
  • 119
  • 217
SARIKA
  • 71
Are fully connected layers necessary in a CNN?
No. In fact, you can simulate a fully connected layer with convolutions. A convolutional neural network (CNN) that does not have fully connected layers is called a fully convolutional network (FCN). See this answer for more info.
An example of an FCN is the u-net, which does not use any fully connected layers, but only convolution, downsampling (i.e. pooling), upsampling (deconvolution), and copy and crop operations. Nevertheless, u-net is used to classify pixels (more precisely, semantic segmentation).
Moreover, you can use CNNs only for the purpose of feature extraction, and then feed these extracted features in another classifier (e.g. an SVM). In fact, transfer learning is based on the idea that CNNs extract reusable features.
nbro
  • 42,615
  • 119
  • 217
In theory, you do not need fully-connected (FC) layers. FC layers are used to introduce scope for updating weights during back-propagation, due to its ability to introduce more connectivity possibilities, as every neuron of the FC is connected every neuron of the further layers.
nbro
  • 42,615
  • 119
  • 217
The reasons people use the FC after convolutional layer is that CNN preserves spatial information. You said you use softmax, so you probably make some classification task. If you don't use FC layer, then you probably evaluate first class by first position of the first kernel, not by whole image with all kernels, second class by second position of the kernel and so on.
The dense net combine the info from all the kernels in all positions.
That said, you technically can convert FC to Conv net, as described here, so then you can said you "skipped" FC layer.
Kirill Fedyanin
  • 694
  • 14
There are mainly two main reasons for which we use FCN:
  1. If we use a fully connected layer for any classification or regression task, we have to flatten the results before transferring the information into the fully connected layer, which will result in the loss of spatial information.
  2. Usually, the parameter cost of using a fully connected layer is high as compared to convolution layers.
Srajan
