Is there any way to make deepfake videos without a fancy computer? For example, run the DeepFaceLab on a website so your own computer won't get involved?
Yes. There are services that provide free environment to run jupyter notebooks for research purposes (with GPU included, which is crucial for neural networks) - such as Google Colaboratory and Kaggle Kernels. Although they limit how long your computation may run (12 and 6 hours accordingly), which adds some difficulties to the process, although I think it is possible to bypass these restrictions.
- 121
- 3
Take a look at using AWS You can spin up an instance with as much processing power as you need and by using their pre-built images it will already be preconfigured with a lot of the packages etc you might need for any kind of ML.
I see you wanted to use DeepFaceLab which I guess requires some kind of GUI so unsure if this is suitable for your requirements but check it out, it seems to be the best way to perform high-processing machine learning without the fancy computer
- 111
- 2
