I am reading Francois Chollet's Deep learning with Python, and I came across a section about max-pooling that's really giving me trouble.
I am unable to copy-paste the content, so I've included screenshots of the paragraph that's troubling me.
I simply don't understand what he means when he talks about "What's wrong with this setup?" (towards the end).
How does removing the max-pooling layers "reduce" the amount of the initial image that we're looking at? What are the benefits of using max-pooling in convolutional neural networks, as opposed to just using convolution layers?
nbro
  • 42,615
  • 119
  • 217
MaxPooling pools together information. Imagine you have 2 convolutional layers $(F_1, F_2)$ respectively, each with a 3x3 kernel and a stride of $1$. Also, imagine your input is $I$ is of shape $(w,h)$. Let's call a max-pooling layer $M$ is of size $(2,2)$.
Note: I'm ignoring channels because, for these purposes, it's not necessary and can be extended to any amount of them.
Now you have two cases:
  1. $O_1 = F_2 \circ F_1 \circ I$
  2. $O_2 = F_2 \circ M \circ F_1 \circ I$
In these cases, $shape(O_1)=(w-4, h-4)$ and $shape(O_2)=\left(\frac{w-2}{2}-2, \frac{h-2}{2}-2 \right)$. If we plug in dummy values, like $w,h = 64,64$, we get the shapes become $(60,60)$ and $(29,29)$ respectively. As you can tell, these are very different!
Now, there is more of a difference than just the size of the outputs, each neuron holds a pooling of more information. Let's do it out:
  1. Each output neuron of $F_1 \circ I$ has information from a $(3,3)$ receptive field.
  2. Each output neuron then of $F_2 \circ F_1 \circ I$ has information from a $(3,3)$ receptive field of $F_1 \circ I$, which, if we eliminate reused nodes, is a $(5,5)$ receptive field from the initial $I$.
  3. Each output neuron then of $M \circ F_1 \circ I$ has information from a $(2,2)$ receptive field of $F_1 \circ I$, which, if we eliminate reused nodes, is a $(4,4)$ receptive field from the initial $I$.
  4. Each output neuron then of $F_2 \circ M \circ F_1 \circ I$ has information from a $(4,4)$ receptive field of $M \circ F_1 \circ I$, which, if we eliminate reused nodes, is a $(8,8)$ receptive field from the initial $I$.
So, let us discuss these: Using max-pooling reduces the feature space heavily by throwing out a lot of nodes whose features aren't as indicative (makes training models more tractable) along with it does extend the receptive field with no additional parameters.
mshlis
  • 2,399
  • 23
