I am quite new to Deep Reinforcement Learning, and I'm trying to define states in a Reinforcement Learning problem. The environment consists of multiple identical elements, and each one of them is characterized by different features of the same type. In other words, let us say we have $e_0$, $e_1$, and $e_2$. Then, suppose that each one is characterized by features $f_0$ and $f_1$, where $f_0$ belongs to $[0, 1]$, and $f_1$ belongs to $\{0, 1, 2, 3, 4, 5\}$. Then, $e_0$ will have some value for the features $f_0$ and $f_1$, and the same goes for $e_1$ and $e_2$.
How can I encode such states?
Can I simply vectorize such state by concatenating the different features of each element obtaining $[f_{0e_0}, f_{1e_0}, f_{0e_1}, f_{1e_1}, f_{0e_2}, f_{1e_2}]$, or should I use a convolutional architecture of some sort?
nbro
  • 42,615
  • 119
  • 217
Stencil
  • 113
For general advice about state representation, you could check my answer to How to define states in reinforcement learning? - this does not cover your specific issue, but may help with other details such as whether to one-hot-encode and/or scale your discrete features. Also you will want to assess whether any state vector you construct actually contains enough data for reinforcement learning to work.
Assuming that is all good, then your approach here:
should work with a generic feed-forward neural network with two or more layers. As this is simple to construct, then it is a reasonable place to start just considering development time. If nothing else it can be a benchmark against other representations and model architectures that you may want to try.
That will depend on any structure inherent in your environment. The interesting thing about your description of the environment is the repetition of meaning in the values. Each entity $e_i$ appears multiple times, and the units of feature $f_{0e_0}$ will be the same as $f_{0e_1}$.
An unfortunate consequence of using a flattened vector is that the information about these repeated entities and their units is lost to the system. Any important details due to the entities being essentially the same of this must be "rediscovered" by the approximator training with many examples. Although neural networks can generalise function results, this does not apply to generalising across different parts of the input unless you choose an architecture designed to help with that.
Typically you would use a RNN architecture (such as LSTM) if key information is in the sequence order of entities, or a CNN architecture if key information is in local patterns between neighbouring entities. By "key information" I mean whether useful relationship to a value function or optimal policy depends on those factors. This might be difficult to assess for some environments with mixed data types and complex meanings for the entity ids - so you may have to experiment with multiple architectures to figure out what factor is more important. However, it is also possible you have some insight based on known good policies, so can head more directly to a promising feature representation and architecture.
Learning may benefit if instead of ordering your entities arbitrarily by identity in the vector, that you sort them according to some factor that is relevant to the goals of your agent. I have used this is in a colour matching environment where an agent had to hit a target with a "current" colour selection whilst avoiding incorrect colours - sorting target entities by whether they matched colour and then by angular distance to the agent's aim enabled the agent to learn its task far more efficiently. This sorting may help independently of architecture choice - i.e. you don't need to be using a RNN or CNN to see a benefit with this approach.
Another thing worth considering, but probably not possible here because of the continuous feature $f_0$, is whether you can invert the representation so that instead of being based on entities with properties, it is a view over property space populated with entities in certain positions. A CNN processed over a small enough "property space" instead of "entity space" may well perform better - this is why board game RL tends to treat the board positions as defining feature vector indexes which represent which entities are present on them, which is a very sparse structure that can represent far more states than ever occur in real games. The over-specified space works because it can be matched to architectures that generalise efficiently over it.
In general, you need to consider different types of symmetry within the system - especially what is meaningful about the id number you have assigned to each entity. If the entity id is not meaningful, or is secondary to some other factor, you have some flexibility in changing the representation to make it meaningful and use architectures that take advantage of how you have injected that domain knowledge into the q function approximator. If the id is meaningful, think how could you best represent the difference between entities with different ids in your environment?
Neil Slater
  • 33,739
  • 47
  • 66
