In the Constraint Propagation in CSP, it is often stated that pre-processing can solve the whole problem, so no search is required at all. And the key idea is local consistency. What does this actually mean?
nbro
  • 42,615
  • 119
  • 217
Lexi
  • 109
If we can do some reduction in the search space using CSP (constraint propagation) we can drastically reduce the search space or sometimes completely avoid the need for a search by directly reaching the solutions (for e.g. with variables having their domains reduced to size one). It could also happen that we come to a point when a variable domain size becomes zero, in that case no solution exists, given the constraints, so no need for a search.
Constraint propagation basically involves the concept of enforcing local consistency (this is done by enforcing node-consistency, arc-consistency, path-consistency and also global constraints using Alldiif or Atmost).
The terms: nodes, arc, path, etc. basically reflects a CSP problem represented as a graph with nodes as the variables and the arcs/edges as constraints. The process is simply to remove values from the domains of the variables that are inconsistent. Algorithms such as AC-3, PC-2, etc. precisely are for these purposes.
